One thing leads to another, SixGun >
Old 08-11-2013 | 01:09 PM
  #41
Zero Patience's Avatar
Yes that was me at the Fort Island ramp, tested the gauges on the river yesterday. Pulled out this morning.
Zero Patience is offline
Old 08-19-2013 | 07:21 PM
  #42
mmb
Hey Buddy couple questions for you! Did you use the same plug in trans with your #6 as you did with Konrads? I have 1450 11 clutch trans now... Will those work if I switch to #6?
Also how much higher do you think my engines will move? I have SSM 3A (Konrad PRS III Conversion) any ideas??
mmb is offline
Old 08-19-2013 | 07:45 PM
  #43
The transmissions are the same, however the tail stocks must change To #6 plug in or close couple. They are very expensive so shop wisely. About 6 k each. The gimbal / transom assembles must be close couple also. Drive lines style will not work in a Top Gun. The engines will only move about 2 inches up, but because the 6 is so short, the entire transom must be replaced, or layer filled and made into a blank slate. It's all in the thread . I would only use a Dry Sump 6, because it is a lot of work and expense. Don't forget the new tailpipes, and finding the right props at 10 k per set is a pain in the a$$ I still am looking for 17.75 x 33 x 18 rake, 5 blades.
Did you come to crystal river? I was away last weekend but MRPs staggered Top Gun was on the river.
Old 08-20-2013 | 06:30 AM
  #44
SS930's Avatar
Basically you're much further ahead just buying a #6 boat rather than trying to convert to one! I have a nice 37 OL with dry sump 6's sans power I'm willing to sell if you're looking, haha!
SS930 is offline
Old 08-20-2013 | 06:39 AM
  #45
just got my boat in the water after rebuild the pain goes away fast just don't look back yes you will be happy
trannyjoe is offline
Old 08-20-2013 | 02:17 PM
  #46
mmb
Thanks for the info! These Konrads are actually working pretty good right now! Just want to start researching this stuff before I change them. We put in at New Port Richie by Joe and ran around there.
mmb is offline
Old 08-20-2013 | 02:20 PM
  #47
mmb
lol I'm actually having a debate with Joe @ Fast Forward about what drives will be cheaper to switch too... Arneson or #6. I like the Arneson and Joe wants me to put 6's on. We are gathering info and will decide what direction we will go with the boat after we look at all the costs involved!!
mmb is offline
Old 08-20-2013 | 02:23 PM
  #48
mmb
Amen brother!! First time it hits the water all day you start figuring out what you can spend money on next!!
mmb is offline
