Water Pressures >
Water Pressures
Water Pressures
Old 08-26-2013 | 01:55 PM
Default Water Pressures
Anyone running blower motors without thermostats and what kind of water pressures are you getting?
Flamingo 42 is offline
Old 08-26-2013 | 02:38 PM
mmb
15-18psi on mine
mmb is offline
Old 08-26-2013 | 03:25 PM
Is that running or at idle? I finnally got all the sand out of the hoses and am getting 10 psi running and 0 at idle
Old 08-26-2013 | 03:53 PM
mmb
Running, they read zero at idle or close to it. I just make sure the sea strainer is swirling and water is coming out of the pipes!!
mmb is offline
Old 08-26-2013 | 04:26 PM
10 at idle , 30 wot
kennyd is offline
Old 08-26-2013 | 08:16 PM
Zero Patience's Avatar
O at idle, 10 at 3500. Temp never passes 100.
Zero Patience is offline
Old 08-26-2013 | 08:25 PM
I wasn't sure if not having the t'stat would drop the pressure, I'm still going to keep checking for sand but water is swirling and squirting so I hope all is well
Old 08-26-2013 | 10:13 PM
mmb
This is the pump i run.
http://www.keitheickert.com/p-26381-...letoutlet.aspx
My water temps stay at 100 also
mmb is offline
