knowledge base >
knowledge base
knowledge base
Old 12-15-2014 | 07:21 PM
you can find a lot of the items you are looking for here.
http://greatlakesskipper.com
boatnt is offline
Old 12-15-2014 | 07:55 PM
Replace both ignition switches while you are at it Phil. They all eventually go bad and can create a momentary loss of ignition because of wear from the keys hanging with heavy key rings jerking on them over the years not to mention them getting wet and corroded.
tommymonza is offline
Old 12-15-2014 | 08:31 PM
i only have 1 set of keys. both are the Cig emblem keys. both keys will turn one switch. but neither for the one that wont turn. the cafe both keys turn both motors.
does anyone know about the fuel sender length? thanks for the replies all!
315duramax is offline
Old 12-15-2014 | 08:44 PM
So the one switch doesnt turn.... simple pull the switch and take the switch and key to a decent locksmith, problem solved,
phragle is offline
Old 12-15-2014 | 08:56 PM
well i sent lipship an email rather than a phone call. Maybe they were busy today. Well see what i get back.
Old 12-15-2014 | 09:17 PM
sounds like a General Motors recall
88bullet is offline
Old 12-15-2014 | 09:23 PM
Trust me the ignition switches are nothing special and easily bought off the shelf. Phuck the Cigarette keys and get some new ignition switches and eliminate a future problem on a old boat.For what it will cost for a locksmith you can replace them .
Old 12-15-2014 | 09:30 PM
The Flat deck senders are 15" .. maybe that helps
ICDEDPPL is offline
Old 12-16-2014 | 07:27 AM
Drake22.250's Avatar
15 in mistress 85
Drake22.250 is offline
Old 12-16-2014 | 08:15 AM
donzi matt's Avatar
I don't know about all that. Phil is selling what is essentially entry level to the Cig crowd. Most of these guys love the idea of setting their keys with the Cigarette emblems down at the table. Kind of an ego stroke. A pair of ignitions with keys is $160 bucks from LipShip, and they will be matched when you get them. It is one of those finishing touches that people really appreciate.
donzi matt is offline
