Water pressure with SM gen III
Adjustable pickups are all the way in pressure is 26psi @4500 (didn`t take go past that)
They are dry so I`m dumping water over board with a 3/4 to -12 on each tail @ transom.
(2) -4 lines off back of each intake.
-6AN blow off valve on bellhousing cooler.
Take out blow off valve (restrictive ) and run straight -6 line or increase size
shaving down the pickups I`d like to leave as a last option.
Dan, I ended up installing adjustable water pressure relief valves to control the water pressure. I don't have the adjustable pick-ups like you but my water pressure was around the same as yours. No problems since installing the relief valves. I ordered mine through Kieth Eichert....see below
Water Pressure Relief Valve 3/4" NPT
128-5002
Adjustable Water Pressure Relief Valve 3/4" NPT
This spring loaded adjustable water pressure relief valve is perfect forbleeding off excess engine water pressure caused by pressure spikes in anengines cooling system. water flows freely when water pressure exceeds theset designated pressure. Keep high pressure spikes from damaging yourengine.
Adjustable from 7-25 PSI.
128-5002
