-   -   rub rail screws (https://www.offshoreonly.com/forums/cigarette/331058-rub-rail-screws.html)
tcwcar 09-24-2015 01:01 PM
rub rail screws
I miss placed a few of my rub rail screws, and bought some replacements a the local hardware store, they keep rusting, I pulled one the original screws out, and one of the replacements, the replacements are magnetic the original ones are not, and every hardware store I check there stainless screws are magnetic. my question is does anybody know were I can get the right screws, and what grade stainless they are, they look like there #8x3/4" screws. thanks any help would be great...
Griff 09-24-2015 01:49 PM
http://www.mcmaster.com/# or
https://www.fastenal.com/home
Wally 09-24-2015 02:44 PM
Stainless can still be magnetic if its manipulated enough during the machining process of making the parts! Easier thing to do is to passivate the screws and they will not rust anymore. The rust is just iron particles on the surface of the raw stainless parts that weren't machined. Some of our 316 stainless pumps we make rust on the raw cast parts even after machining them...never on the machined parts.....so we dip them in a solution of nitric acid for about 10-15min....never rusts again... we use this stuff:
http://www.citrisurf.com/cs77Pinfo.htm
we buy it by the gallon....
tcwcar 09-24-2015 07:30 PM
thanks guys
frickstyle 09-25-2015 09:11 AM
What Wally said. Also, make sure to buy 316 where possible, alot of the hardware stuff is junk 304 or 18-8. 316 is sometime 2-4X the cost, but I always try to use it when possible.
pm203 09-25-2015 09:22 AM
What is a rub rail and do I need one?
tcwcar 09-25-2015 02:05 PM
I'm sure Phil can screw one on that Glad if you think you need it...
pm203 09-30-2015 01:47 PM
You can always use one. You just have to adjust your docking procedures without one.
