Cafe Racer throttle question >
Old 04-30-2016 | 09:25 PM
SB
That place is impressive, I just snooped around their site:
http://www.ottoexcellence.com/about/visual-tour.aspx
SB is online now
Old 04-30-2016 | 09:49 PM
These guys make some cool switched I`ve used in my boat
https://www.oznium.com/switches
ICDEDPPL is offline
Old 04-30-2016 | 09:54 PM
SB
Cool, I like this: https://www.oznium.com/about
SB is online now
Old 05-23-2016 | 12:37 PM
donzi matt's Avatar
Here is what I ended up doing. I replaced the port and starboard start switch as well as the parallel start switch with the push buttons I listed above. They look nice, seem to be decent quality also. I had to drill the plate to 5/8 so they would fit. The parallel switch is actually a two position switch so what I ended up doing with that is moving that switch down to the side where my now defunct fume alarm had a switch mounted and installed the push button as a blank. It all works as it should and things are much more comfortable with the shifter.
[ATTACH=CONFIG]555871[/ATTACH]
[ATTACH=CONFIG]555872[/ATTACH]
Attached Thumbnails Cafe Racer throttle question-img_2878.jpg   Cafe Racer throttle question-img_2879.jpg
donzi matt is offline
