Cafe Racer throttle question >
Old 11-10-2015 | 02:42 PM
donzi matt's Avatar
Default Cafe Racer throttle question
I am looking to change the throttles on my Cafe. Currently I have Kiekhaefer controls that were originally canted forward. When the motors were changed to EFI motors it was found the throttles hit the dash before WOT so the handles were switched around to be canted backwards. This actually makes your right arm motion pretty awkward at 1/2 throttle or under. I would like to change to a set of Marine Machine throttles (I found a set) but they are a straight handle. Does anybody know if the straight handles will allow WOT without hitting the dash? It's kind of a big gamble without knowing. I am attaching some pictures of the current setup, maybe it will give some perspective.
[ATTACH=CONFIG]547568[/ATTACH][ATTACH=CONFIG]547569[/ATTACH][ATTACH=CONFIG]547570[/ATTACH]
Attached Thumbnails Cafe Racer throttle question-img_2518.jpeg   Cafe Racer throttle question-img_2519.jpeg   Cafe Racer throttle question-img_2521.jpeg
donzi matt is offline
Old 11-13-2015 | 11:54 PM
make a template of the lollypop and stick out of card board, then tape it at the knee joint and check your clearance, take into account your fingers gripping the handles,
I'CE is offline
Old 11-14-2015 | 09:02 PM
thisistank's Avatar
My gun had straight sticks. No problem at all.
You can actually see on one of the pics you posted with the throttles forward that it wouldn't be a problem. You can follow the line of the throttle before it dog legs and there's plenty of room!
thisistank is offline
Old 11-14-2015 | 09:32 PM
donzi matt's Avatar
Thanks guys,
I ran a straight edge and think I am fine as well, but being that it is a pretty large investment, I figured I better ask the experts first.
Thank you again.
Old 11-15-2015 | 06:57 PM
We have 500efis with straight sticks
1MOSES1 is offline
Old 11-20-2015 | 12:33 PM
Originally Posted by donzi matt
Thanks guys,
Thank you again.
Our cafe had the same issue, at WOT our knuckles would hit the trim tab controls...smart move on switching the throttles around. Our trim tabs had a small 1/2 inch spacer plate between the dash and the switches which didn't help our case either. Marine Machine throttles look good! Goodluck
Nickotine is offline
Old 11-20-2015 | 01:56 PM
I have straight Livorsi, and I would post a picture, but I lost 5 years of my build history when computer took a dump. You should be fine.
frickstyle is offline
Old 11-20-2015 | 02:22 PM
anewway's Avatar
Straight Livorsi here as well, no issues with hitting. Don't have a pic full forward though.
[ATTACH=CONFIG]547878[/ATTACH]
Attached Thumbnails Cafe Racer throttle question-set-up-cockpit-helm-throttle-radio.jpg
anewway is offline
Old 11-20-2015 | 04:46 PM
YEP! ^^^ Dem 'er it!
Old 11-20-2015 | 07:42 PM
Zero Patience's Avatar
I have done A half dozen or so. I use the straight Livorsi with trim in the handle on all. No problems.
Zero Patience is offline
