Bottom Work begins
Strake removal, blueprinting, fixing bottom damage, full polish begins
http://33outlaw.zenfolio.com/img/s5/...24185500-4.jpg http://33outlaw.zenfolio.com/img/s9/...34305536-4.jpg http://33outlaw.zenfolio.com/img/s6/...50947755-4.jpg http://33outlaw.zenfolio.com/img/s6/...73453817-4.jpg |
What is your expected change from the strake changes?
Who is doing the work Dan?
Clyde:
http://bowkersfiberglass.com/contactus.htm So far great service and pricing. Little Red: Speed . Less transom lift should equal more bow lift. |
Looking forward to hearing the good results!
I think I need to take a road trip out to Chicago this fall and just drop off my boat off with Dan. You guys are always embarking on some serious projects. I think you get Cabin Fever.
I figure in 3-4 months, we will probably have at least 2-3 more " Cigarette Adventures" documented from ICDEDPPL. This is awesome work and just beyond a love of the sport. Doing all that bottom work, you might as well just add Steps and make it the first Flat Deck Cigarette TS. Not like you don't like a good project. Good luck with everything, can't wait to see it all. |
I agree with cigrocket. Its awesome to see someone take such pride in an older boat........and NEVER give up on it! This boat has come so far. Nice work Dan. You've done a great job on this boat....its a good thing you don't like money! Hahaha...
1 Attachment(s)
Originally Posted by kreed
(Post 4416994)
^^^^^ Soooooo true. ^^^^^^
Great work Dan . In addition to the stern strake surgery , did consider lengthening the forward strakes to aid in bow lift ? Or would that make it to squirrelly .
Rick g. |
Originally Posted by cigrocket
(Post 4417007)
I agree with Kreed, I am pretty sure we don't like money. When we have some, we tend to say......I bet I could go faster, look better, ride better, IF........ and then POOF !
Originally Posted by Rick G
(Post 4417079)
Rick g. |
Originally Posted by ICDEDPPL
(Post 4416856)
Clyde:
(Post 4417079)
Rick g. Knot For You: I have my reasons, rather not get into it . With Bowkers, I like the price( a lot) cleanliness of the shop, updates with pictures, communication and he`s done a ton bottoms.etc etc. |
Bowkers did that work to my 34 SCARAB - I only gained about 1 MPH but it did settle the transom and helped handling in the rough. He also did all of the work on my Daytona.
He does good work for a fair price. |
love it, if anyone has seen this boat in person it's absolutely amazing looking, just gets better!!
Thank penis!
Full Force - do you have any more pictures of the babe in your avatar???
OUCH |
Anytime sizzlenuts....
(Post 4417326)
Thank penis!
I wish... hahha
Originally Posted by Tinkerer
(Post 4417327)
OUCH |
(Post 4417163)
I did not consider that but it is a good point. I just don`t know anyone who has done that and what affects it would have. Deleting some of the rear strake has been done before with good results. Our boats do need as much bow lift as possible thou.. hmmmm
Dang that's far away.
Dan are you going to round the end of the strake like the front one or just finish it off square ?
Rick G. |
Looks like he`ll be finishing it square.. Ill know more when it`s done
The only reason i asked is being so close to the transom will it create a disturbance in water flow to props the front ones are rounded for that reason I am guessing .
Just a thought better to consider now before you are finished. I wonder if the notch I added affectively accomplished the same result as your strake sugary . Cheers RG. |
That`s a good point, I`ll bring that up to Martin. Maybe leaving it square acts like a tiny step :p
I`ve always thought the notch was designed to deliver cleaner water to the prop and to allow the engine to be raised even further then normal. |
You are probably right about the notch , it was a thought as the notch affectively reduces the wetted surface at the transom and I thought that might reduce stern lift some what . I am certainly no marine engineer .
RG. |
The notch does the same thing as an extension box. And I believe he will end the strake with a sharp square edge. A square edge will cause the water to break clean from the hull. The reason the front one is rounded is it is easier to build the boat that way.
Tinkerer is right.
The best way from a performance stand point is the way shown in the photos. Other methods are used throughout the industry, but are typically done to make the boats easier to build and also less mold maintenance Progress: Previous repair: http://33outlaw.zenfolio.com/img/s6/...66888095-4.jpg Touch ups: http://33outlaw.zenfolio.com/img/s5/...46543777-4.jpg sprayed: http://33outlaw.zenfolio.com/img/s10...90346236-4.jpg In Gel: http://33outlaw.zenfolio.com/img/s5/...66929876-4.jpg |
Looks good, Im still amazed those little jacks hold the monsters up
Great work Dan . I see the drives are on , were the motors out during the process and did he reinforce from inside?
RG. |
Motors are out, I had some typical delamination in the bilge so that`s getting fixed along with a scratch in the paint from an anchor. I don`t see a reason to reinforce anything from the inside . Not his first rodeo so I trust whatever needs to be done will be.
Sorry Dan , wasn't questioning his workmanship. Just asking one can never learn too much , his work looks great .
RG. |
Damn that looks like a lot of work, why not just build a bigger motor?? :party-smiley-004: lol, my boat is coming off the trailer this weekend, bring a longboard....
2 Weeks worth of work , all is finished. 30 year old dull bottom full of dings and scraches looking like new again.:bananalove:
Biggest hook was between Strakes, should be a better more efficient ride. Delamination in Bilge http://33outlaw.zenfolio.com/img/s5/...03139545-4.jpg Almost done. http://33outlaw.zenfolio.com/img/s9/...04429863-4.jpg http://33outlaw.zenfolio.com/img/s4/...91650778-4.jpg http://33outlaw.zenfolio.com/img/s11...42536199-4.jpg shine: http://33outlaw.zenfolio.com/img/s3/...47258371-4.jpg |
Was that actual delamination or was it just a cosmetic surface coating that cracked. I have seen Where they just coated over existing gellcoat with a new layer.
Standard Ciggy tabbing Delamination.
Tim will be happy to hear this but it happened after Lake Erie and some big water.:D |
(Post 4420936)
I thought those boats were unbreakable?
| All times are GMT -5. The time now is 12:23 PM. |
