-   -   Okay here is a noob question (https://www.offshoreonly.com/forums/cigarette/336789-okay-here-noob-question.html)
mmb 04-29-2016 12:47 PM
Might want to try changing the neutral switch, my port engine was hard to find a spot so it would crank, put new micro switches in and it all went away. My controls cover the micro switch for about 5-10 degrees movement, well before it shifts into gear. So Even though there is no detent it is almost impossible not to find neutral with the new switches installed.
Not sure about you not being able to find neutral while docking, I just listen for the engine to rev up..... That sounds like something other than the neutral switch. Something going bad on the cable connections etc, i would start inspecting everything last thing you want to do is crash into a dock.... Seen that happen in Key West something was broke and he couldn't shift to Neutral or Reverse it just stayed in forward.
BMBoyer 05-03-2016 03:16 PM
I just finished Tres Martins course and he said the shifters just needed to be greased so I am trying that first.
RebarBox 05-03-2016 03:37 PM
Sounds cheap!:D
BMBoyer 05-06-2016 05:18 PM
grease helped a lot but she is still pretty sloppy in and out of gear, Going to have my mechanic take a look at it next week when the boat is in for drive spacers, a leaky steering cylinder and a couple of other little things. May add mufflers too.
Griff 05-07-2016 01:34 AM
Why does it need drive spacers???? It doesn't look like it has shorty drives???
If you want to take some bark off the exhaust note, I'd just get some GGB inserts.
I highly doubt you need new shifters. The MM's should last forever. I think its more about getting used to the feel of them.
I have Latham's and they are great. Nuetral has a detent stop, so you know when you're exact, but I've never had a problem being able to tell with others brands after I got used to them either.
BMBoyer 05-07-2016 09:25 AM
It's very prone to blowing out on start, any positive tab makes it almost impossible to get on plane. I took the Tres Martin course last week and when Tres drove it he said it needed 1/2" to1" spacer. Have to believe he knows what he is talking about.
BMBoyer 05-10-2016 12:15 AM
Okay. Shop said to try some new wheels before spacers so that's what we are doing. They recommended some 5 blade 28s instead of the 4 blade bravo 30s I have now to help with the blow out and limited trim reaction (I can go from 4 to 9 on the trime indicator with no appreciable change in bow height or rpm above 60mph)
Any recommendations on 5 blades to try?
tommymonza 05-10-2016 05:30 AM
Originally Posted by BMBoyer (Post 4432699)
My new to me 2002 Playboy has sloppy shifters, have to hunt for neutral all the time and I am being pretty deliberate in my movement not tentative. Now I have been around boats a long time and to me this seems to be out of adjustment but maybe I am just spoiled by the DTS in my other boats now. What would be the quickest, easiest corrective measure I could try to provide smoother shifting and a more definite detent in neutral?
Everything appears to be factory build on the 500EFIs and XR drives.
I used to date a Girl with Sloppy Shifters. She was a lot of fun but I could never get her in gear at the right time.
F-2 Speedy 05-10-2016 07:10 AM
What rpm are you turning the 30's ? five blade is a lot of wheel for a 500, but will bite better.
BMBoyer 05-10-2016 08:29 AM
Only getting 4800 with the 30s. Can barley get the to 5000 over trimming and loosing speed.
