Replacement Vents for Tiger >
Old 06-29-2016 | 09:42 PM
Default Replacement Vents for Tiger
Does anyone know where I can get new vent inserts for my 99' Tiger? I was told that they were made by Cigarette....any ideas
Flamingo 42 is offline
Old 06-30-2016 | 12:05 PM
CIG3's Avatar
Any fab shop should be able to make those for you. You will play hell trying to get them out of Cigarette. Your only other option might be to give Phil at Lipship a call.
CIG3 is offline
Old 06-30-2016 | 08:49 PM
Called Phil first...not available, all mine are intact but starting to get some corrosion so I was going to try and remove them to paint. When I put a screwdriver to the first screw it felt like it would twist off so I stopped there, figured I would see if they were available before proceeding.
Old 07-01-2016 | 06:32 AM
offshoredrillin's Avatar
I lost one and phil had one left a couple years back. They are through bolted and they can be re drilled to put in new studs.
offshoredrillin is offline
Old 07-04-2016 | 09:34 PM
I think I'll touch them up and try to remove them after the season if they don't look good
