575 SCI Alarm buzzer >
Old 09-03-2016 | 11:22 AM
Default 575 SCI Alarm buzzer
I have a 42 tiger with twin 575 SCI Mercruiser motors, the Port side motor alarm started out intermittent then lately is staying on the whole time, both oil pressure and water temperature are perfect on the gauges, thinking bad sensor, any thoughts from anyone?
Jkosch is offline
Old 09-03-2016 | 12:58 PM
The alarm sensors are separate from the guage sensors. The alarm sensors use a tan with blue stripe wire.
I think the only things that trigger an alarm on a 575sci are low oil psi, high water temp and low drive lube.
Disconnect one sensor at time to find the bad one. Also, check the drive lube bottle for sludge at the bottom preventing the sensor from working properly.
Griff is offline
