Originally Posted by Drake22.250
(Post 4494752)
[ATTACH=CONFIG]560941[/ATTACH][ATTACH=CONFIG]560942[/ATTACH]
Goning to get power figured out and then dial in with props. If the boat doesn't like the drives then next winter will be #6 drives. |
Originally Posted by frickstyle
(Post 4494921)
Let me know when you sell those Arnesons!
(Post 4494752)
(Post 4494210)
buddies got a 04 that has the same set up and has hit 89. Wonder how much hp is needed to break 100mph?
[QUOTE=Quinlan;4494376]Schweeng I have the hatch that is painted on the sides and has a slight rise to upholstery .....the center has the "1" cutout for more air
Stock blowers.... the Whipple intercooler is low profile in my opinion - def not as tall as a super chiller or something like that. |
[QUOTE=Schweeng;4495321]
Originally Posted by Quinlan
(Post 4494376)
Stock blowers.... the Whipple intercooler is low profile in my opinion - def not as tall as a super chiller or something like that. Hey Chris. What gun did you buy? Pic? |
Originally Posted by Relaxing
(Post 4495301)
If you keep trying to fix stuff that's not broken, your wife is going to have you mounted on the wall next to your wolf.
5,500 rpm crusing, that be him
(Post 4495370)
If she only knew, she still thinks that you pull the engines to winterize. :champs:
Glovers old gun
http://www.offshoreonly.com/forums/c...ml#post4473479 |
(Post 4495301)
Originally Posted by Schweeng
(Post 4495423)
Glovers old gun
http://www.offshoreonly.com/forums/c...ml#post4473479 Damn dude. Nice!! Always liked that ride. |
4 Attachment(s)
I've been working on dialing in my 39 with Arnesson's over the past few weeks. I tried out my backup props I bought this summer for the first time on Tuesday night and gained 20 mph at 5K RPM's. The Arnesson's are proving to be the real deal thus far. I'll post some videos when I figure out how to post to youtube.[ATTACH=CONFIG]561048[/ATTACH][ATTACH=CONFIG]561049[/ATTACH][ATTACH=CONFIG]561050[/ATTACH][ATTACH=CONFIG]561051[/ATTACH]
A couple of videos out testing....
https://youtu.be/12B2KlmTi-Q
https://youtu.be/hulpq3T9dic
And a little Borla exhaust action https://youtu.be/z5-4PADW-YI
(Post 4494752)
Brent, video's look awesome, you did a great job with your boat! What have you seen top end and cruising speeds? Like your valve covers, will have the same soon. Any trouble getting on plane with the 17.5 compared to the 18inch?
Looking Great man- Now drag that Beeech up to GLOC some time!
Originally Posted by easyrider1340
(Post 4494657)
I figured you would have popped 100 - you've got big power!
By the way, got it back together yet? What was the issue in Nashville? Terry Locked up the motor when a crank failed in Nashville, trashed the engine with 15-20 hrs on it. Back to rebuilding and winter time stuff. Maybe next year.... |
(Post 4496089)
(Post 4496077)
As for getting on plane with the smaller props, that was my biggest concern, but it seemed to be the same. I hope Mark can help with the take off power band. I have to play with the throttle between 2400 to 2800 RPM until the props break loose a bit to get the RPM up, and then it grabs.. And you better be holding on to something. Hunting season is officially started for me so test and tune will be put on hold for a couple of months. FYI, the Tickfaw 200 is only 6 months away.... JS |
Originally Posted by brentadkins
(Post 4496053)
Originally Posted by kreed
(Post 4496133)
WOW....20 MPH gain? Where did you start and end up on speed? Did you make any others changes besides the drives?
Thanks for the info, hunting season starts September 1st for me. Too many bad habits!
Brent's up to 107, wonder what's the fastest T/S 38 Top Gun?
(Post 4496541)
https://www.youtube.com/watch?v=OlqkaUzKJ50 |
love this....Tom's got a a couple football fields between the competition AND he's still behind the sea wall.....
That things a beast, what power is in hot for a teacher? Sweet 39 just listed in classifieds at legend.
Well, if we're talking top speed in a twin step Top Gun, I have cruised (in fresh water no less) at 120MPH with my current wheels on M8 Drives with QuadCam 1100's in my Gun. It's a custom built "one of one" Cig 39 from 2012. The boat has more speed with different wheels, but I am content with this set up which adds great handling and safety. The boat is no nonsense at 110mph
https://www.offshoreonly.com/forums/img_1080.mov
Not many V bottoms can out accelerate me from 40 mph to 120. Just saying. The video attached was a fuel burn before pulling the boat for the season a few weeks ago and I was doing around 100mph
(Post 4496667)
(Post 4496077)
With Arnesons, are you "stuck" with whatever prop shaft height you end up with on install/mounting height? That can be real tricky on the older hulls with custom combinations....
My buddy's TG with 598 Zuls about 725HP with Xrs an d Imco lowers runs 98-100 .
My buddy's TG with 598 Zuls about 725HP with Xrs and sportmaster lowers runs 98-100 .
(Post 4496914)
Originally Posted by Rik
(Post 4497557)
The prop shaft height is adjustable as it has hydraulic trim. The transom mounting heights are fixed as the drives are bolted to the transom so ass u ming that the installer installed the Arnesons correctly then all is good.
How is the plug-in? Can you run a driveshaft into the drive? Engine -> Trans -> Driveshaft -> Input shaft of the Arneson ? (Using the previous SSM setup / rigging)? Do engines need to move "down"? |
these are some good running boats
(Post 4497796)
Right, I understand the trim, but that comes with "angle" similar to a conventional outdrive. I guess my question was more like having adjustability on boxes, there really is none with the arneson design and no way to add "spacers" like a bravo or SSM derived design. you answered my question. The only way to adjust "true" prop shaft height would be to re-glass transom, drill holes and re-mount drives, correct? So it's very dependent on initial setup. Do you offer proven mounting templates for these hulls?
How is the plug-in? Can you run a driveshaft into the drive? Engine -> Trans -> Driveshaft -> Input shaft of the Arneson ? (Using the previous SSM setup / rigging)? Do engines need to move "down"? Drive line setup is easy as the input shaft just accepts the drive line yoke. Real easy. The engine placement is "dependent upon" where it's at. There are so many different X dimensions on each boat that it's difficult to say off hand. The engines do seem to drop though by an inch or two normally. |
(Post 4497796)
1 Attachment(s)
[ATTACH=CONFIG]561277[/ATTACH]
Here is how they are mounted |
| All times are GMT -5. The time now is 02:00 AM. |
