Twin step T/G Speeds >
Old 11-02-2016 | 12:43 PM
  #71
With Arnesons, are you "stuck" with whatever prop shaft height you end up with on install/mounting height? That can be real tricky on the older hulls with custom combinations....
frickstyle is offline
Old 11-03-2016 | 10:43 PM
  #72
sre's Avatar
sre
My buddy's TG with 598 Zuls about 725HP with Xrs an d Imco lowers runs 98-100 .
sre is offline
Old 11-03-2016 | 10:45 PM
  #73
sre's Avatar
sre
My buddy's TG with 598 Zuls about 725HP with Xrs and sportmaster lowers runs 98-100 .
sre is offline
Old 11-03-2016 | 10:48 PM
  #74
sre's Avatar
sre
This one here
http://www.offshoreonly.com/classifi...un-o67239.html
sre is offline
Old 11-04-2016 | 09:31 AM
  #75
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
The prop shaft height is adjustable as it has hydraulic trim. The transom mounting heights are fixed as the drives are bolted to the transom so ass u ming that the installer installed the Arnesons correctly then all is good.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 11-05-2016 | 10:04 AM
  #76
Right, I understand the trim, but that comes with "angle" similar to a conventional outdrive. I guess my question was more like having adjustability on boxes, there really is none with the arneson design and no way to add "spacers" like a bravo or SSM derived design. you answered my question. The only way to adjust "true" prop shaft height would be to re-glass transom, drill holes and re-mount drives, correct? So it's very dependent on initial setup. Do you offer proven mounting templates for these hulls?
How is the plug-in? Can you run a driveshaft into the drive? Engine -> Trans -> Driveshaft -> Input shaft of the Arneson ? (Using the previous SSM setup / rigging)? Do engines need to move "down"?
Old 11-05-2016 | 09:35 PM
  #77
these are some good running boats
Boatlesss is offline
Old 11-06-2016 | 05:08 PM
  #78
Rik's Avatar
Rik
We have a drill template that lays it out really good. It places the drive in the correct location. No need to have to redrill the transom.
Drive line setup is easy as the input shaft just accepts the drive line yoke. Real easy.
The engine placement is "dependent upon" where it's at. There are so many different X dimensions on each boat that it's difficult to say off hand. The engines do seem to drop though by an inch or two normally.
Rik is offline
Old 11-06-2016 | 06:17 PM
  #79
On my boat a 1 degree change in prop shaft angle results in a half inch of vertical prop height change. When rigging Arnesons get them as low as you can without dragging the socket in the water too much.
kvogt is offline
Old 11-07-2016 | 11:09 AM
  #80
Rik's Avatar
Rik
[ATTACH=CONFIG]561277[/ATTACH]
Here is how they are mounted
Attached Thumbnails Twin step T/G Speeds-38-cigarette-top-gun.jpg
Rik is offline
