-   -   Steering column options (https://www.offshoreonly.com/forums/cigarette/345873-steering-column-options.html)
Rhythm and Blues 04-01-2017 07:00 AM
I'm trying to figure out a way to re-angle my steering column...if at all possible... I was curious if there was a angled shim one could fit to the Char-lynn valve then a tapered collar for the base of the steering column. Or if that's a fictional pipe dream what are my options; I'm looking to be able to tilt the wheel up another 10 degrees +/-. Apart from a new Zeiger or Imco tilt helm were there any other nice OEM helms to look for? Didn't some older TGs or Cafes come with tilt helms? Thanks guys..
class6 04-01-2017 07:31 AM
If the helm is long enough, you can use angled plates inside and out, enlarge the hole and possibly need longer bolts. Without grinding any glass.
Zero Patience 04-01-2017 08:59 AM
It's tight back there, no room for shims. The Tilt is the way to go, the Everett performance is nice. But I have never seen a need to change it. I'm 6'4 and it's great
Rhythm and Blues 04-01-2017 09:58 AM
Thsnks guys. Wonder what years tilt helms came stock on in terms of cafes or earlier strait bottom TGs..
Griff 04-01-2017 12:55 PM
1 Attachment(s)
That is basically what was done on my 32 AT. No brand name on the piece.
Rhythm and Blues 04-01-2017 02:03 PM
Ok, so theoretically parts do exist to achieve this, correct?
Griff 04-02-2017 12:39 PM
It did in 1997 when my boat was built. The outside part is nice billet piece. The backside has some wedge plates.
Rhythm and Blues 04-02-2017 03:19 PM
Ok, good to know; I appreciate the follow up. I guess this warrants some investigation..
RebarBox 04-03-2017 08:26 PM
http://www.freeportmarine.com/boat-s...ree-wedge.html
Had tilt with the old cable steering column on the Bicycle. But we are currently putting full Mayfair steering on had to look at this option. By reversing the wedge - It helped us push the 4" column helm back in the dash to gain some needed space.
Rhythm and Blues 04-03-2017 09:22 PM
Alright thanks; is that plastic? Do you have some good pics of your assembled helm?
RebarBox 04-04-2017 05:48 AM
I just ordered a couple days ago. I should have it installed by the end of the week.
Rhythm and Blues 04-04-2017 06:31 AM
Ok, roger that.
Griff 04-06-2017 10:08 PM
2 Attachment(s)
Here are a couple better pics of mine. I'm guessing it may have been made by Marine Machine which is outta business. No brand name markings on it.
Mine also looks like the back part of an Imco HP-4 helm post http://www.imcomarine.com/nvcatalog/imco_catalog.pdf
You could try and contact Pat at AT and see if he knows.
buck183 04-06-2017 11:06 PM
"Needed space"? Are you saying you need more leg room? That's funny!
Rhythm and Blues 04-06-2017 11:07 PM
Oohh, that looks like it'd work. Thanks for the leed. I'll continue the investigation...
I see that hp4 15 degree post now. I'll give them a call 2morro...
Quinlan 04-07-2017 04:35 AM
Is it LEG room that you gain when you tuck in the wheel lol
