Sea strainer isolation valves...? >
Old 05-10-2017 | 08:59 PM
Rhythm and Blues's Avatar
Originally Posted by ICDEDPPL
What happens if a hose pops off, bursts, etc? The boat will be at the bottom of the lake .
I have shut off valves screwed directly to the pickup, no hoses inbetween. Used for emergencies only.
I hear that Daniel, I'm probably going to pull the motors for the off season so if I cant get at them now then surely I could go that route at that point. Along the same lines I thought of threading a ball valve into the strainer but what stopped me is the leverage the nipple and valve would have on the tigged fitting if left unsupported. I figured for now I'll do a valve close to the strainer w 2 barbed ends so its: through hull fitting-hose-ballvalve-hose strainer. Thats a great suggestion you have but I kinda feel the same way about it as threading a valve into the strainer in terms of hanging leverage. Are the valves you have on your intakes supported in addition to being threaded in?
Rhythm and Blues is offline
Old 05-10-2017 | 10:48 PM
Your idea will work just fine (barbed ends) , I`ll take a picture for you tomorrow, might make more sense . the pick up is what supports the valve. I see what you mean by threading into the strainer ... sounds iffy
ICDEDPPL is offline
Old 05-10-2017 | 11:49 PM
Cool, looking forward to the pics; thanks.
