Need some prop help
Plug in your numbers Prop Slip Calculator
For Bravo 1 props, reduce the pitch by at least a 1/2 inch of what they are stamped.
Your prop slip is still high at over 19% and I think it would just go higher with shorty lowers.
I would try and find a pair of stock 30 Bravo's to test. Ideally, if you can spin 30's close to 5000 rpms, then they would be perfect candidates for labbing.
Custom labbing with some added cup and maybe rake done will get more speed and bow lift.
BBlades labbed my props. They were thinned slightly and cup added. I gained 2-3mph and 150 rpms without having to trim as high.
Also, I would check the bottom of the boat for some hook in the last 4-6 feet closest to the stern.
