Electric help >
Electric help
Electric help
Old 08-30-2017 | 10:45 AM
Default Electric help
86 cafe racer
I have no power to circuit 50 on the fuse panel. I also have no power to switch for nav/anchor. Is 50 the circuit for that
Blackmagic94 is offline
Old 08-30-2017 | 01:15 PM
CIG3's Avatar
Should be power from Port Battery. Curcuit #50 is Fuel pump. Nav lights should be #23
CIG3 is offline
Old 08-30-2017 | 02:19 PM
BDiggity's Avatar
It's been so long, i cant remember if the engine switches in cabin need to be on to then power the fuel pump circuits.
23 is for the nav's as stated above.
BDiggity is offline
Old 08-30-2017 | 03:49 PM
I've tried it both ways but that far left circuit. Not sure if 51 now has no power on test light on either side. I have no stern light and I have no nav and anchor lights nor does the switch light up.
Old 08-30-2017 | 03:50 PM
If I remember correctly the electric fuel pumps go through a oil pressure switch to get power.
kvogt is offline
Old 08-30-2017 | 03:52 PM
Fuel pumps have power
it's not circuit 50. But there are two dead. Far left and one middle one with a top black wire. I'll go look in a bit and get numbers.
Old 08-30-2017 | 03:57 PM
Also what type of anchor light fixture does these use. Not a normal perko twist pole
Old 08-31-2017 | 01:41 PM
CIG3's Avatar
Perko Figure 1125 (3 pin)
Perko Figure 1209 (2 Pin)
CIG3 is offline
