help! need to empty cafe racer 1990 head >
Old 05-04-2020 | 01:32 PM
Default help! need to empty cafe racer 1990 head
Before beginning our year on this beauty, please tell me how you empty the head on this boat. Is there a valve that you turn? Do not have the owner's manual.
Thanks in advance.
caferacer012199 is offline
Old 05-04-2020 | 02:10 PM
BDiggity's Avatar
Thanks in advance.
According to the manual i have:
1. Close small inlet valve
2. Close large outlet valve
3. Connect shoreside vacuum to wast deck fill on starboard side of deck.
BDiggity is offline
Old 05-04-2020 | 03:48 PM
seafordguy's Avatar
Mine is different. There are two buttons.
The one that says "push to flush" simultaneously pulls water in through the small valve located under the stbd seat while also pulling the waste into the holding tank. From there you can suck out at a Marina, or open the big valve and pump over board by pushing the other button.
Brian, yours is an 89 if I remember. I think the 90's were more likely to have the set up I mentioned.....
seafordguy is offline
Old 05-04-2020 | 04:34 PM
BDiggity's Avatar
Mine is a 91, & had the two small buttons (ive since removed it). I thought he was wanting to just pump the holding tank.
BDiggity is offline
Old 05-04-2020 | 07:06 PM
seafordguy's Avatar
You may be right. Either way, OP don't leave anything in the tank. They will smell so bad it will take you years to get rid of the smell - ask me how I know
