Top Gun Hatch Leaking
The port hatch on our 2001 Top Gun leaks when washed. I thought it was the rubber seal that was the problem but discovered this was not the case.
The last time we washed the boat we lifted the bow of the boat using a forklift on the trailer. I was inside the cabin and noticed the hatch started to slowly leak. The water was leaking where the stainless trim piece meets the fiberglass opening. my question is where is the water coming from. I know there is a drain that is supposed to drain any water that accumilates around the hatch opening and was wondering if this could be leaking internally. If anybody has this same problem or knows what could be causing it I would appreciate any help. |
I have the same problem I've been trying to figure out with a bullet. I think it's the same design. I blew air thru the drain thinking that was it, tryed new rubber and that did'nt stop it either.
I just spent over $500.00 replacing the all the hardware for those hatches and they STILL LEAK !!! I dont know what more can be done to stop this. If you look into the gasket area you can see sunlight between the gasket and the deck in some spots.
Bob |
I even tried a rubber weather strip on the deck portion of the hatch and I'm in the same boat. I'm stumped.
I thought it was the rubber as well, but when I was inside the cabin and watched it starting to leak I noticed it was not comming from the rubber seal. It seems to be coming internally from the deck, and leaking between the fiberglass and the metal trim. That is why I was wondering if the drain was somehow the problem, maybe draining internally into the deck were the opening for the hatch is. I left a message for Bud at Cigarette, if I get an answer I will let you guys know. At least I know mine is not the only one.
Try removing the the spring lock brac. and use some silicone and reinstall maybe it's leaking through the screw holes!
I will try that, thanks...
leak
If the drain is plugged it will leak via rubber seal and sometime where the hatches are pinned. you may try pulling the insert out of the drain and reseal it. I have never experienced any leakage from the deck
The drains seem to working fine and I don't think the rubber is the problem. Thanks for the suggestion though.
How would you go about unplugging the drains, and were do they drain to ??
Bob |
They drain overboard above the rubrail by the front of the fairing. You will see a small drain hole molded into the deck.
I would think you could blow some air through them and possibly clear any abjects. If that does not work then you would have to remove the inserts like Tres said. I have run water through mine so I know the work. |
Ill try that , Thanks havabrew
Run a coat hanger through the drain hole works for me!
| All times are GMT -5. The time now is 12:19 PM. |
