Ext Boxes On A Cafe Racer >
Old 09-23-2005 | 07:29 AM
Havasu Hangin's Avatar
Arrow Re: Ext Boxes On A Cafe Racer
If you raise the X (with the box)...I believe you'll need to raise the engines.
Unless the cav plates are too low, I'd just put shorties on.
Havasu Hangin is offline
Old 09-23-2005 | 07:57 AM
Sean's Avatar
Default Re: Ext Boxes On A Cafe Racer
HH,
I've been thinking about that too...
From what allan was saying, it sounded like 2" shorties weren't enough...and that they went up a total of about 5" I think I'll have some room under the hatch to go up if I need to...
this should be an interesting project..
I can see myself spending way more money than I originally intended...or than the boat is worth...but it wouldn't be the first time (I'm in the process of building the most expensive 16' Superboat center console ever)
Sean is offline
Old 09-23-2005 | 10:15 AM
birdog's Avatar
Originally Posted by Sean
I've thought about it too...and I'm sure Konrad build a great product but in the end, i'd like to stay with mercury...
I dont get it, sean...Why would you go to all the time & expense to change to a drive you know will not live ?....&
chance screwing up your CG in the process ....
birdog is offline
Old 09-23-2005 | 10:34 AM
Sean's Avatar
perhaps i'm in denial because i think the bravo will live...besides, i don't plan on putting big power in it right away and by the time i do, perhaps mercury will have come out with a replacement for the bravo that will handle bigger power...not to mention all of the aftermarket upgrades available for the bravo drive.
and the reality is, i'll probably never put more than 600hp in the boat anyway. my boating philosphy is focused on reliability and while many think the bravo is unreliable, if properly maintained and used, it should certainly last behind a boat like mine.
as far as the CG is concerned, while there is a "chance" of screwing it up, i've done a bit of research and talked to several who think the added setback will enhance performance given a proper x-dimension. I can fool around with moving the engines back and forth to make sure i get the right balance without too much trouble... i think
besides...extension boxes with polished shorties will look real cool
Sean is offline
Old 09-23-2005 | 11:33 AM
birdog's Avatar
Thanks for the reply.....Having had Alpha & Bravo boats all my life & now having trans, I couldnt imagine going back. Thats why i asked...When I was T/G shopping i planned on a TRS boat & upgrading to Konrads. Got lucky & found a SSM boat..
And yes I agree..Ext boxes & polished lowers ARE cool !
birdog is offline
Viper31
Scarab
0
09-06-2008 07:56 AM
frinaudo
Fountain
5
06-03-2007 10:32 AM
SummerObsession
25
11-14-2004 10:13 PM
CAFE
08-07-2003 08:46 PM
