-   -   Cockpit flooring...... (https://www.offshoreonly.com/forums/cigarette/69119-cockpit-flooring.html)
jawbreakerkid 01-20-2004 09:54 AM
rtn137- looks great!! what type of preparation did you do to the orignal floor before you applied the epoxy?
chad
rtn137 01-20-2004 11:57 AM
1 Attachment(s)
jbk,
Nordic uses a wood floor with the carpet glued down.
Pulled up the carpet, the easy part, then scraped and sanded until flat. resealed a little with some resin and sanded a little more. I didn't worry to much about sealing, I figured the epoxy spread all over would do that. Its not super critical but the Lonseal isn't very thick so bumps and waves will show.
Also they make the white wave pattern with UV protection and without, so make sure to get the UV protected type.
FWK 01-27-2004 04:44 PM
My partner can get this for you also he is in the flooring business. If you go through a marina ou will pay alot more for the lonseal. I am having him order some for my boat.
THEJOKER 02-18-2004 05:22 PM
I am amazed that Nordic doesn't have a composite liner in the floor. That wood will eventually be rotten. BH
