-   -   herrings on tiger? (https://www.offshoreonly.com/forums/cigarette/69964-herrings-tiger.html)
BaReNBoO42 01-24-2004 04:33 PM
herrings on tiger?
Just wondeirng about herrings for the tiger. what do you think the speed increase would be? midrange increase?. the boat is currently running 500efis with non labbed bravo 4 blade 28's and hitting 81 bouncing off the rev limiter. post thoughts about the 5 blades and the 6 blades
GLH 01-24-2004 07:37 PM
IF your hitting the rev limiter go up one size and get labbed. Sounds like your currently underproped.
I did the same thing at the beginning of the summer and gained 2.5 MPH.
Hot Boat had your rig in their test at 82.3 MPH must of been labbed prop on it then.
Cannot help you with Hering's but Phil Lipshutz would know all about those.
BaReNBoO42 01-26-2004 10:23 AM
so you think i should stick with the fourblades? i have tried a set of 30s and they just didnt turn up to where they should have, they were at like 4900rpm
OldSchool 01-26-2004 11:33 AM
Lab the 30's. That should put you right at 5200.
GLH 01-26-2004 01:06 PM
If you get labbed 30's it should get you within 500 rpm from where you were with the 28's. You won't hit the rev limiter then, might gain a couple MPH also. That is what I experienced with my Cig last spring.
From what I have read a 5 blade might help with cruise efficiency, take offs and so forth no as much on top speed.
For a beautiful rig like that, I do not see the sense in not running labbed props at all, unless you bang up props a lot.
topgunrcf 01-26-2004 01:53 PM
well it is pretty shallow around here. espicially where im always getting on plane. i havent dinged a prop yet but how durable are they? are they that delicate?
Barrett
BaReNBoO42 01-26-2004 01:58 PM
whoops, didnt mean to post under my dads name.
Jamie B. 01-26-2004 02:53 PM
Re: herrings on tiger?
Have you asked Bud ?
GLH 01-26-2004 03:39 PM
That might have some answers for you.
http://www.hydromotive.com/info.html
BaReNBoO42 01-26-2004 04:51 PM
has anyone tried the hydromotive p5's? if so how r those?
