-   -   Towing a Bullet w/a k2500? (https://www.offshoreonly.com/forums/cigarette/81550-towing-bullet-w-k2500.html)
THRILLSEEKER 06-18-2004 06:51 AM
Ok, I know it will be a hefty load, but I think the power train will handle it......how can I beef up my suspension to better handle the load?
GLH 06-18-2004 07:02 AM
Re: Towing a Bullet w/a k2500?
Firestone Airbags
I think you have plenty of truck
Chart 06-18-2004 07:41 AM
If you have rear drum brakes on the burban, then your front brakes arn't that good either. (the dealer service manager said "But they meet the legal requirements.")
Change out your front brake pads to ceramic pads. They stop better, and don't have brake-fade issues. The first use of them in the morning is weak, but from there you're golden. Also, make sure the rear drums are frequently adjusted during pulling season. Don't count on the automatic adjusters to do this. Also, make sure the trailer brakes are working right, and doing their part.
Make sure you have E rated tires, or 10 ply rated tires, the same thing. I think your truck uses size 245. If they're bigger than that, then D may be okay. No one ever regretted having too strong a tire when pulling. There may be a slight trade-off in ride.
Good shocks are a good idea.
I pulled a heavy boat similar to yours thousands of miles on a Myco steel trailer with a 1500 suburban with 150,000 miles on the odometer with the above mods and the Firestone airbags. It did better than it should have. You're going to be great with a 2500 and the same mods.
Chart 06-18-2004 07:43 AM
I just re-read your post, and you might have a pickup instead of a suburban. Doen't matter. Same things apply.
OldSchool 06-18-2004 08:02 AM
1 Attachment(s)
I tow my Bullet with a K2500 Suburban. It does a great job with the 454 (except at the gas pump!). I did add the AirLift 1000 rear airbag system and liked the results alot. :)
OldSchool 06-18-2004 08:09 AM
I forgot to add that mine has the 46MM Bilstein shocks, HD tranny cooler and all of the "other" towing goodies. :cool:
GLH 06-18-2004 08:22 AM
1 Attachment(s)
Well Craig our rig came with all that!!!! :D:D
OldSchool 06-18-2004 08:26 AM
:p :p ...and a 10000 lb tow capacity. What does that 42 and the trailer weigh? :D Don't forget to factor in the weight of all that fuel!! :eek:
O.C.Barry 06-18-2004 10:25 AM
I've towed our Top Gun with my 2002 6.0 2500 HD with no problem. You'll be fine.
birdog 06-19-2004 07:53 AM
Just make sure you buy one that has 6 disc brakes on the trailer !! :p
Tim G. 06-19-2004 12:11 PM
Brakes are everything!
Spend the extra coin on a nice trailer with DISCs on all three axles.
I just moved a 42 #6 Tiger on a steel MYCO, with two Sterlings on pallets in the back of my truck.... I've never seen my 1 ton dually squat like that before, but everything was smooth.... The 454 and 4l80E did fine...I was just sure not to push it real hard.
THRILLSEEKER 06-21-2004 08:53 AM
dog.... :D
you wouldnt happen to know where one may be do you? :crazy:
RUSSSR1 06-24-2004 10:28 AM
It all depends on how fast you need to get where you are going. When over taxing your truck you better adjust your speed. I tow a 38 flatdeck with a 93 smallblock K2500, does just fine but I don't push it past 55mph. Truck does have 4.10 and tripple trans coolers, never tow in overdrive and use 4wd low to pull it from the water. For a bullet you should be just fine.
THRILLSEEKER 06-24-2004 02:33 PM
WOW!!
thats a load :eek:
MrCIG 06-24-2004 04:05 PM
2 Attachment(s)
I tow a old 38 Flat Deck with a Custom Built steel trailer with my V10 Excursion. It probably weighs more them GLH's 42. I do use weight distributing bars and it tows fine.
MrCIG 06-24-2004 04:10 PM
1 Attachment(s)
Here are the weight dist connections
