prop selection >
prop selection
prop selection
Old 08-24-2004 | 09:17 AM
lucky strike's Avatar
Default Re: prop selection
Originally Posted by 38cigmike
I have a 1982 38ft Cigarette with normally aspirated 600HP and TRS drives. Before I refurbished the boat I
had 26p 3 bladed cleavers. At that point the boat had about 500hp per side and the boat would run about
69mph on the GPS @ 5400 rpm. I since then have put a set of 4 blade 26P Hydomotives and the boat has a little better cruising speed but I only can run about
59 mph at 4900 rpm. I am more interested in cruising
but is there a prop in between these I should consider.
I sent you a PM Mike.
lucky strike is offline
Old 08-24-2004 | 09:32 AM
cigarette1's Avatar
Member #2 ....Jeeezz
There ya go ... experience and lots of it.
G
cigarette1 is offline
Old 08-24-2004 | 10:39 AM
Tres,
Good question on the GPS. I think statute but I need
to confirm. I bought these props from you (Used). Is the
weight of my flat deck more than a Top Gun and if so
wouldn't it have an effect on prop selection?? The figures
I got on the engines are from a desktop dyno which does
not take the hardware, transmissions, etc. into consideration.
38cigmike is offline
Old 08-24-2004 | 11:31 AM
Tres's Avatar
Yes, a marine dyno, with the sea pump , alt, and water jacketed exhaust.
Tres is offline
Old 08-24-2004 | 05:04 PM
MrCIG's Avatar
Charter Member#330
Tres,
Those speeds on the TG's was that with a notch transom? Or not notched? I heard the notch gave them almost 5MPH.
Mark
MrCIG is offline
Courtholl
Pantera
8
03-31-2007 10:13 AM
speedboatr
Prop Talk
3
08-31-2006 06:22 AM
RACER8
Skater
2
07-21-2004 03:31 PM
RACER8
1
07-19-2004 11:37 AM
phastang
2
04-24-2002 07:46 AM
