Gas Tanks
Old 10-26-2004 | 08:08 AM
gripit's Avatar
Default Gas Tanks
There are 2 gas tanks in the Bullet. Does each engine run off of there own dedicated tank or is there some common line that feeds both engines. I was just woundering because one of my tanks was so much fuller than the other.
gripit is offline
Old 10-26-2004 | 08:53 AM
DanB's Avatar
Charter Member #71
Default Re: Gas Tanks
What motors? 502mpi's? Usually ea motor has its own tank.
DanB is offline
Old 10-26-2004 | 09:05 AM
gripit's Avatar
Mercruiser 420 hp's.
gripit is offline
Old 10-26-2004 | 10:17 AM
OldSchool's Avatar
In mine, one tank feeds each engine. No crossover.
OldSchool is offline
Old 10-27-2004 | 05:16 PM
FLYLOW's Avatar
My '94 Bullet has each tank feeding an engine and there is a crossover valve on each tank.
FLYLOW is offline
Old 05-19-2005 | 06:10 AM
gripit's Avatar
How about the fuel pump switchs on the dash. I have 2 of them. Does it matter if they are on or off. I have been running with them in the off position and it runs fine? Just wondering what would happen if I run with them in the on position??
gripit is offline
Old 05-19-2005 | 06:26 AM
OldSchool's Avatar
You probably have mechanical fuel pumps, so the switches are just for looks.
Old 05-19-2005 | 10:19 AM
Cigaretteman's Avatar
Donīt you have the electric "diesel pumps" in a Bullet ?
In my Top Gun the electric pumps kicks in if the fuelpressure gets to low and the mechanical pumps canīt keep up.
Show me a picture of the forward part of your engineroom and I will tell you if you have the electrical pumps.
Cigaretteman
Cigaretteman is offline
Old 05-19-2005 | 10:54 AM
gripit's Avatar
How is this pic?
gripit is offline
Old 05-19-2005 | 11:19 AM
OldSchool's Avatar
Cigaretteman
Mine has been converted over to just electric pumps only.
