Anyone replace trim tab actuator cables? >
Old 11-14-2004 | 03:18 PM
BillR's Avatar
OSO Moderator
Default Anyone replace trim tab actuator cables?
I want to replace the mechanical trim tab actuator cables on my K-Planes. I have one that could be questionable. I can't see where the length is written anywhere on the old cables.
Has anyone replaced these on a TS TG? If so, do you remember the lengths?
Thanks in advance!!
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 11-14-2004 | 03:28 PM
lucky strike's Avatar
Default Re: Anyone replace trim tab actuator cables?
I did just 3 weeks ago, I believe it was 19 feet, had to special order it in black.
L.S.
lucky strike is offline
Old 11-14-2004 | 03:34 PM
BillR's Avatar
OSO Moderator
Both sides? I thought port side would be longer???
Thanks LS!
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 11-14-2004 | 04:12 PM
Thanks LS!
Only replaced the starboard.
L.S.
Old 11-14-2004 | 04:49 PM
DanB's Avatar
Charter Member #71
While were on the subject...that face plate on the dash with the clear plexiglass in it, that covers the indicators...does it just pop off or is it bolted down?
DanB is offline
Old 11-14-2004 | 05:11 PM
CMG's Avatar
CMG
contact c/s at Cigarette, I am sure they will have the part number / lengths readily available. If they don't - get a Formula! Best C/S regardless of age.
Chris G.
CMG is offline
Old 11-14-2004 | 07:43 PM
I just replaced the port drive cable on my 28ss. there were no markings on it at all I yanked it out and it was 20ft.
..word of advise use some washers and nuts to "jam" a heavy wire on one end of the cable, pull the old cable out attach wire to new cable and pull new cable back thru..works like a charm.
THRILLSEEKER is offline
Old 11-14-2004 | 08:32 PM
Comanche3Six's Avatar
The cable should be marked on the outer housing 1 or 2 feet from the end. Morse 33c supreme series are top shelf units.
Good luck
Ed
Comanche3Six is offline
Old 11-14-2004 | 10:00 PM
Bolted down------is your plastic not looking as good as it should ?
Old 11-15-2004 | 09:47 AM
DanB's Avatar
Charter Member #71
Thanks LS
Not lookin as good as I'd like. I've replaced everything else on the dash and that kinda stands out. Guess I'll have to pull the dash again to get behind it.
DanB is offline
GoFastSonic
Sonic
4
08-05-2008 10:52 AM
BL6
2
04-22-2008 08:54 PM
powerquest280
Sonic
1
04-17-2008 06:49 AM
powerquest280
Sonic
6
04-14-2008 08:03 AM
pachangalpina
Fountain
5
01-28-2005 07:49 AM
