trs plug
Old 11-22-2004 | 02:06 PM
gripit's Avatar
Default trs plug
I have a trs drive and on my drive shaft housing there is a plug that is described as "plug,trim tab hole". Anyway, my plugs are missing and I noticed that there is water sitting in that hole. I don't know how much water that hole holds but I am concerned about how to drain that hole. Also, what is the purpose of that hole. In the winter the water in that hole may freeze and cause damage. What should I do ? Please Advise?
HERE IS A LINK TO A PARTS DIAGRAM ITS PART #8
http://www.mercruiserparts.com/Show_...+GEAR+ASSEMBLY
gripit is offline
Old 11-23-2004 | 11:08 PM
stecz20's Avatar
Default Re: trs plug
its if what i think it is its the hole right above the zinc. the only reason for the hole is to get an alan wrench in for the zinc. not a problem and it will not do any damage when it freezes. it it bothers you suck out the water and get a cap for it from mercruiser. stecz
stecz20 is offline
Old 11-24-2004 | 09:54 AM
gripit's Avatar
Yes, that is what it is! How do I get that to drain?? There has to be something clogged because my other drive isn't holding any water in that hole? What do you think?
gripit is offline
Old 11-24-2004 | 02:31 PM
stecz20's Avatar
dont even worry about it, im sure if you take the zinc out it will drain. im sure you can suck it out if it bothers you that much. i had the same concern and was told not to even bother with it. go to the auto parts store and get a primer pump. small hand primer, to get it out and go to mercruiser and get the plug. im sure its like .50 or a 1.00 cant be much. no worries, it wont do any damage. but if it makes you sleep better, get it out. stecz
stecz20 is offline
siearly
Drives and Lower Units
14
09-23-2023 06:19 PM
BY U BOY
07-16-2008 12:08 AM
jeff1000man
02-27-2007 09:45 AM
baja bailey
11-10-2002 12:50 AM
