Tiger Handling Characteristic >
Old 01-31-2005 | 09:16 AM
Tres's Avatar
Default Re: Tiger Handling Characteristic
First check a few things, Check to see if the Xs are true. I have found a few that are not , either side to side from center or from each side. Next look for a shrinkage in the glass on the left area in front of the notched transom just outside of the rounded area. Does the boat ventilate in a accelorated planing? Because of the bottom design , quite a few of the cigs need lowered Xs. Switch your props and try to see if it is a prop problem it will come out in the switch.
Tres is offline
Old 01-31-2005 | 09:43 AM
Feelin Nauti did your 93 Fountain come from grand, if so i believe it was John Mullins personal boat for a short time.
alpine99 is offline
Old 01-31-2005 | 11:28 AM
Registered User
Flawless looking rig.. goodluck with your prop issue.. your X dim.. looks real conservative..have you tried the boat out in the rough to see the effect of its performance?..
MIAMIBOYZ is offline
Old 01-31-2005 | 11:58 AM
mismatched X-dimensions? On a boat of that caliber and that kind of $$ ?
now that's worriesome...
Rippem is offline
Old 01-31-2005 | 12:49 PM
InXS's Avatar
Thanks for the thoughts Tres. I will check the X's and will post back with the measurements if they are not true. The boat does ventilate getting to plane. My gut feel is that it will be either a need for lower X's (like you mentioned, also 2112 mentioned spacers) or just a change props. At this point, I am just waiting for spring to get the boat back in the water so I can start working with it again.
Thanks,
InXS is offline
Old 03-20-2005 | 04:18 PM
Been awhile, curious if you had a chance to try new props yet? I am looking at a similar setup to yours so curious about your results.
corey
lonestar382 is offline
Old 03-25-2005 | 05:00 PM
TIGER-1's Avatar
InXS
Call Bud at Cigarette or Phil at LIP-SHIP Performance.Both will give you the correct answers and not try to get in your pocket by talking you in to something you don't need.
TIGER-1 is offline
Old 03-26-2005 | 09:15 AM
jawbreakerkid's Avatar
I would take the advice that Tres has provided.....it is free and we all know that Tres could rig a Cig blind-folded. Normally people charge for that kind of info......ie. attorney's, consultants, doctors, etc. Thanks for being involved on the board Tres.
Chad
jawbreakerkid is offline
OL40SVX
Superboat
9
12-29-2005 10:14 PM
epeek
Fountain
8
07-26-2005 11:15 AM
n2boatn2
5
05-31-2005 04:42 PM
jeffro
Scarab
3
08-19-2002 07:32 AM
502KC
Fountain
8
05-27-2002 08:54 PM
