help buying a bullet >
Old 01-16-2005 | 10:18 AM
Default Re: help buying a bullet
Right at 70 no more no less
Dirck W Gomez is offline
Old 01-16-2005 | 10:24 AM
all great advise and thanks...any suggestions to surveyers in Seabrook Clear Lake ARea of Tx to recommend?
Old 01-16-2005 | 10:32 AM
CMG's Avatar
CMG
not to be a pessimist, I'd ask the dealer who they recommend and make him the one you avoid. Anyone they have a relationship with would be suspect, especially since you from way out of state. If they have a faorite - theres a reason.
good luck
Chris G.
CMG is offline
Old 01-16-2005 | 10:44 AM
cbdragon's Avatar
What year? Tranporter to have insurance. Survey...yes. Sea trail..... yes.
cbdragon is offline
Old 01-16-2005 | 10:52 AM
Its a 1990 bullet with stepped hull. 502/415 mags repowered in 99. Vessel is listed here in OSO.
Old 01-16-2005 | 11:04 AM
clearcut3's Avatar
DO NOT buy a boat without a survey. That is too much money to spend to risk all of the problems that can be hidden (moisture, stress cracks, broken stringers, etc...). It will be the best $500 (give or take) you ever spend. There are plenty of people that spend a couple G's on survey's before they find the right boat. Better to spend $2,000 on survey's for the right boat than thousands of dollars and countless hours fixing someone's problem. Any salesman who tells you not to get a survey on a 15 year old boat is one I would watch out for.
Good luck!!! A bullet is a GREAT boat. just make sure you buy the right one
clearcut3 is offline
Old 01-16-2005 | 11:08 AM
cbdragon's Avatar
Looks nice I'm not sue what you mean by stepeed hull? Notch? Survey runs 10 to 12 dollars per foot not including compression check here?
cbdragon is offline
Old 01-16-2005 | 11:13 AM
It has a notch or pad in the stern of the keel, it is my understanding that only the later Bullets had this notch/pad. Also, does anyone know when did they stopped making the bullet. I read somewhere that they were introduced in 1988?
Old 01-16-2005 | 01:08 PM
OldSchool's Avatar
I'm sure that you've heard the others say this already, but I'll post it one more time just in case.
DO NOT BUY IT WITHOUT GETTING A SURVEY!!!!
I hear that there is a guy named Ed Cozzi that has great pricing on surveys!!!
OldSchool is offline
Old 01-16-2005 | 01:15 PM
cbdragon's Avatar
The notch is correct. cb
cbdragon is offline
