mistress fuel system question >
Old 03-10-2005 | 07:31 AM
ratman's Avatar
Default mistress fuel system question
where are the fuel tanks located in a 1979 mistress? what is the capacity of each tank? on the side of the cockpit below the sticks is a switch that looks like a valve to switch from one take to the other. i will be running big power and don't want fuel delivery problems. what is the best way to plumb the fuel system? should i run 1 engine off each tank and eliminate the switching valve (it's small 3/8th and i will be running #10 fuel lines to the pump) ? thx for any info you can share. ratman
ratman is offline
Old 03-10-2005 | 05:02 PM
Default Re: mistress fuel system question
My 1976 28SS has all three tanks plumbed to two switches, one for each motor, then to two electric booster pumps feeding mechanical pumps on each engine.
Who in the hell thought THAT arrangement up!
JohnJan is offline
Old 03-10-2005 | 05:40 PM
vette131's Avatar
my 78 mistress has a 160 gallon tank under the cockpit floor
& a 60 gal tank under the v birth.
vette131 is offline
Old 03-11-2005 | 11:04 AM
CIG3's Avatar
should be one in the floor and one in the v-berth. about 220 gallons. the valve switches from front to rear tank. should be a valve for each engine.
CIG3 is offline
Old 03-13-2005 | 12:14 PM
ratman's Avatar
who makes manual high flow fuel switching valves with 1/2" min id? i'm going to run #10 fuel line to the pumps and #8 to the carbs for my new motors. thx, ratman
ratman is offline
Old 03-13-2005 | 12:54 PM
'05 Concept SF23
On my Formula I used 1/2" full ported SS ball valves. The need to be rated WOG (water,oil,gas). Imco also has a hi flow electric valve. Why not just plumb the two tanks together and feed each engine separately from the rear tank.
f311fr1 is offline
Old 03-15-2005 | 07:33 PM
Frank Ferencak
Old 03-16-2005 | 04:32 AM
NJgr8ful's Avatar
Originally Posted by Frank Ferencak
edited by Frank Ferencak
ooops ...
Frank Ferencak
Almost your first post Frank
NJgr8ful is offline
Old 03-16-2005 | 06:04 PM
ratman's Avatar
tooo f in funny bro...
ratman is offline
Old 03-16-2005 | 07:46 PM
NJgr8ful's Avatar
so close ... lol
How's the rig coming along rat?
NJgr8ful is offline
