Magnum Sport deck vent/bubble? >
Old 01-16-2007 | 04:55 PM
el indio's Avatar
Default Re: Magnum Sport deck vent/bubble?
marine supply catalog.....been a long time......sold my sport 1984.........
el indio is offline
Old 01-16-2007 | 05:52 PM
24degrees's Avatar
Do you know what happen to the boat?......where is it now?
24degrees is offline
Old 01-16-2007 | 07:53 PM
el indio's Avatar
my boat sunk comming in haulover....a few months after i sold it.....
el indio is offline
Old 01-16-2007 | 09:11 PM
h2oboater's Avatar
Back in the day many of the vents were removed off the Magnums that were raced, my 1976 Mag was gone by 1979 replaced by a flat pice of plastic. The Magnum dealer that sold many of the great Mag's that raced is still around, I called them tonight to see if one might be on a shelf that they took off. It might take some time to look [ off season up here in Michigan ] but it's worth a shot! I will keep you posted.
Attached Thumbnails Magnum Sport deck vent/bubble?-untitled.bmp
h2oboater is offline
Old 01-16-2007 | 10:52 PM
24degrees's Avatar
Thanks man........any help would be very much appreciated.
Old 01-17-2007 | 01:12 PM
dammmagnum's Avatar
Aaron,
Good Day to you. Been a while
Did you try and contact Magnum direct and ask them who made them? They may still have the info around?
Hope your winter is going well
Cold out here for California,, under freezing
Thank you
Jim
dammmagnum is offline
Old 01-17-2007 | 05:44 PM
24degrees's Avatar
Hey Jim....how are ya?
I did check with Magnum a few years ago and they weren't much help. I'm going to south Florida next month and I'll probably stop by the factory and bug them a bit....
Aaron
Old 01-17-2007 | 05:56 PM
Hey DAMMMAGNUM
I see you are from danville ever make it to "PETE'S BRASS RAIL AND CARWASH" Great pace there in your neck of the woods.
oldschoolfan is offline
Old 01-17-2007 | 07:16 PM
el indio's Avatar
based on the 30 year factor.....the cost would be high.it was high back in 72 when i needed one ....2 hunded something......magnum will confirm that it was produced in 2 sizes by sudbury. the malteese has a smaller one....
el indio is offline
Old 01-17-2007 | 07:35 PM
h2oboater's Avatar
24Degrees they looked today no luck, it was worth a try.
