Adding trim Fluid?
Old 05-18-2008 | 08:05 PM
Default Adding trim Fluid?
Ok 1979 Mirage with small blocks. I do not see a resivior for the trim pumps or the trim tabs. The pumps are mounted on the front bulkheads and the lines go right to the fittings on the transom ? My Sonic has resivors for both what am I missing?
GoFastSonic is offline
Old 05-22-2008 | 08:51 AM
NJThumper's Avatar
There is not a seperate resevoir. Its the bottom of the pump. You should have a screw in short dipstick on the pump which is where you add fluid.
NJThumper is offline
Old 05-22-2008 | 08:56 AM
NJThumper's Avatar
Check this:
http://www.mercruiserparts.com/Show_...D+846170A+1%29
Old 05-23-2008 | 02:30 AM
Thanks for the info. Every thing on this boat is different then my Bravo boat.
eliminatethis
12
09-03-2008 08:03 AM
gripit
0
06-06-2005 09:18 AM
tj309
3
03-11-2005 09:57 PM
tmthunder
7
03-25-2004 07:17 AM
bn
09-20-2002 08:03 AM
