-   Classic Offshore (https://www.offshoreonly.com/forums/classic-offshore-199/)
-   -   Merc II TRS Shift Linkage Conversion (https://www.offshoreonly.com/forums/classic-offshore/194900-merc-ii-trs-shift-linkage-conversion.html)
djmadmatt 09-08-2008 06:03 PM
So the Electric worm gear Motor that shifts the Merc II into Forward, Revers and Neutral Died on me today. The metal contacts in its switch housing got all mashed together and were shorting out.
My friend John told me that they used to make a conversion so you could use an actual shift cable and get rid of all the electric BS.
Does anyone know where to get one of these conversions and or if anyone still makes them?
Thanks,
Matt
MOBILEMERCMAN 09-08-2008 06:33 PM
Is it a TRS? The control shifts the transmission? Yes there was a kit. If it is a 215 E with electric shift to the unit not a transmission I think not.
I have the old parts I can look if no one else answers.
Westcoast 09-08-2008 06:47 PM
KC Marine 360-738-3100
He sells all the conversion parts needed
olredalert 09-08-2008 07:00 PM
------I think I have one original conversion and one made by someone as well. I also have two Merc electric shift transmissions in good shape (both shifted well when removed form the fresh water boat) for sale for a nickel apiece......Bill S
djmadmatt 09-08-2008 07:10 PM
Yes .. The Motor Assembly shifts the Transmision on mine. I just want to eliminate the motor assembly and use a manual cable to shift the transmission.
djmadmatt 09-08-2008 07:16 PM
The Transmision seems fine so I really dont want to replace the whole thing, but I'll keep that in mind if I have problems down the road.
djmadmatt 09-08-2008 07:18 PM
I'll give them a call tommorow. Hopefully they're not to expensive. If so I'll be looking for a used one. :grinser010:
Westcoast 09-08-2008 09:42 PM
At least you only need one
djmadmatt 09-09-2008 08:30 AM
hahahahaha ... Yes .. Good Point! But I have a feeling I should change the throttle linkage as well.
http://www.synergyproaudio.com/pix/cobra09.gif
MOBILEMERCMAN 09-09-2008 08:49 AM
You will need A different one.
djmadmatt 09-09-2008 11:29 AM
Called him today. He's gonna get me hooked up with everything I need. Thanks Westcoast.
djmadmatt 09-09-2008 02:48 PM
http://www.synergyproaudio.com/pix/cobrathrottle1.gif
http://www.synergyproaudio.com/pix/cobrathrottle2.gif
http://www.synergyproaudio.com/pix/cobrathrottle3.gif
