Im a ####in sucker and pissed
So I bought this boat , from private owner here in Fox Lake, knowing it had one bad drive , but seller said he had a spare drive up in Oconomowoc ,wis at a buddies marina, oh yes its ready to be bolted on he says, ,,,,,,,,, well I was supposed to get it last week, mind you i picked boat up 2 weeks ago, , the only way i bought the boat because he had the spare drive ,ready to go, well, I just got off the phone with the marina, and they told me the drive is not bolt up ready , it needs ujoints, shaft, bearings, and who knows what else, , I am fuming and could kick my self in the ass ! , and feel like i was shafted good !!! I should have had him write up a detailed bill of sale, detailing everything i get, includeing condition of whole package , now i have two bad drives !!!! #### ME !!!!! , get a detailed bill of sale , no matter what !!
Originally Posted by fasttoys7619
(Post 3348682)
lookin to do a possible trade with anyone in Northern Il,southern wis, or n.w. Indiana,,,,, 2 bad alphas/cash for one good alpha with 1.50 gears, please call me at 815-528-0433, Rich, I need it asap
That sux!!
You might want to get a second opinion on the drives, those are pretty easy to work on and with two drives you should be able to make one. If that doesn't work put an ad on craigslist.com that you want a drive I am sure someone will have one real reasonable or look for a project boat, sometimes you can pick one up that has your drive for a couple hundred bucks.
good luck, if I was closer I would help you out. jim |
so i just spent $45 in gas money to pick this spare drive up, when seller was supposed to get it for me last week, has a bad upper housing, no shaft, broke u joint and bad upper gears and bearings, who knows what else,,,,guy at marina says seller told him he knew drive was bad and said give it to me anyway, , I called seller and asked didnt you tell me drive was ready, rebuilt and ready to bolt up ? he said yes , (me)why did i get a garbage drive ? (seller)I dont know ? marina must have made a mistake.lol , (me)well are you going to make right ? he said I dont know what to tell you , ,, and ended conver like that, now im an easy going guy, very hard to get pissed , I just dont know what this world is comming to,, so many dishonest guys out there , lookin to #### people over
He said it was ready to bolt up he didn't say it would work after it was bolted up. There is a gray area in there. You just bite the bullet and move on brother. Alfa's are cheap you will find one. SOrry you got the shaft and the drive didn't.
Just remember, you're not a Sucker... Someone else was very dishonest..You're like me, you still have faith in our fellow man, unfortunatly there are more dishonest people today than ever. I know right now you are simmering, but like
Velocity Vector said, Thank god it's a Alpha which are readily available & are generally priced fairly. At the end of the day, you have a Beautiful Looking Boat with Great Lines. I've always loved the looks of those Vintage Nova's.. Keep your head out of the bildge & Look towards brighter days my friend..Good Luck Buddy ! |
all is not lost....
http://www.boatstoreonline.com/alpha-drives.html good stuff...in parts! if your upper's shot...grab a lower...or vice your versa... if you don't already run a C/R set up, you should.... you're in good hands with OSO..... c |
Originally Posted by ChristianGott
(Post 3348920)
all is not lost....
Fixx
(Post 3348924)
I have two right hands on the boat now, what kind of gains would i get if i did switch to c/r set up ? i know it would eliminate torque steer, but would i gain any significant speed?, more speed? , thanks ,
Originally Posted by mrfixxall
(Post 3348943)
you wont gain any speed but it will take the lean out of the boat..
I disagree with fixall. If c/r drives don't improve speed, then why do all twin engine race boats run them? c/r drives can work together to lift the boat or hold the boat in place (prop rotation). there are many aspects to consider, but generally speaking the c/r set-up is more efficient at propelling the hull forward because the drives work in conjunction with the hull and the strakes, not against it. .02 c |
I saw a complete Alpha on the Richmond, VA Craigslist last week, in the Boats section.
Give me a call.
Tom Mitchell Cobe Marine 410-255-9488 |
Definitely go for the SEI, I run one of their lowers on my outboard, good piece. As for the C/R, I dunno, prolly handle better.
I know of a pair of c/r alfa ones are for a $1100 a piece all redone
if it helps
Originally Posted by Velocity Vector
(Post 3348868)
Originally Posted by TexomaPowerboater
(Post 3349956)
+1, He may not of known they needed work.
Originally Posted by TMITCHELL
(Post 3349807)
Give me a call.
(Post 3349956)
Originally Posted by Downtown42
(Post 3350002)
why did he take it off and bring to a marina/repair shop rather than leave both on the boat to sell? The guy knew it had issues. At least call the marina you dropped it off and ask them what the deal is and pass it on to the customer.
expose the p.o.s. so he cant screw anybody else .
(Post 3350056)
I don't know and don't care. If he though he was buying a turn key boat he should of done a sea trial. The fact that a sea trial could not be done is representative enough that the boat needed repairs to make it sea worthy. No sympathies, buyer should have checked it out thoroughly.
ok , hers the deal, i bought the boat with two drives on it, I knew one was bad it was locked up, seller told me he had a fresh rebuilt drive at a marina, I went to pick it up and it was trashed, I questioned the mechanic about it and he said the seller knew it was bad and told him to give it to me anyway, on the way home i called seller and asked to confirm; didnt you say the drive was rebuilt,ready to go, he said yes, then i told him the mechanic told me that Jim(the seller told him he knew it was bad and to give it anyway, once i said that the seller(Jimmy) hung up on me, and wont return my calls,lol , he is a pos !! yes i know , with boats should always do a water test, but i did hear the motors run, I did do compression tests, went through all the motor build papers, and i went through the boat hull,mechanicals, and electrical very thouroly, knowing one drive was bad, but what gets me is how someone can blatently lie like that, Dont tell me you have a good spare drive an hour and a half drive each way to get it,when in fact its a pos and wasted my day, that my friends is the story, he is a 30 year old punk P.o.S. |
(Post 3350472)
Out of Curiosity what did you pay for the boat?
Originally Posted by f_inscreenname
(Post 3350527)
Is it anywhere in writing about the drive? You may have a case for court but depends on what you can prove.
anyway, Im in good hands now, a fellow OSO contacted me, and he is rebuilding the second spare drive, it is salvageable, so hopefully this weekend i can do a quick water test, since the water levels are close to normal on the Fox River in McHenry, that is if they dont open the gates any further:drink: |
(Post 3348924)
(Post 3350056)
WOW pull that C@ck out of your azz & smile once in a while TEX :kiss: |
Originally Posted by Baja555
(Post 3350769)
Definitely will see a noticable handling difference with counter rotation drives.. not sure about a speed increase , but I feel you will see some improvement
Originally Posted by RunninHotRacing163.1
(Post 3350805)
No sympathies:eek:
Everyone knows what BOAT stands for: Bring On Another Thousand
[QUOTE=StClairRaceFan;3351417]Everyone knows what BOAT stands for: Break Out Another Ten Thousand:kiss:
Fixed it for ya ..... thats besides the point :eek:sounds like he was a trusting individual and took the guy for his word and as he learned now can't trust some people as far as you can throw them:angry-smiley-038: ..does'nt matter if the boat was 2K your only as good as your word :drink: |
(Post 3351566)
(Post 3351600)
So true in this world.:drink:
:ernaehrung004: |
| All times are GMT -5. The time now is 05:54 PM. |
