MacGyver Supercharger... Interested?
Consider that in most boats, the engine(s) don't usually enjoy direct access to the cool(er) outside air beyond the small amount that finds its way into the bilge through the vents at speed.
Sure, there are always air scoops. But typically, a boat sporting those on its hatch is beyond help when it comes to fuel economy.
Instead of ice, a custom Peltier cold bank might get the job done a little more consistently. Add in an ultrasonic atomizer, and the results would be measurable.
Some years ago, I was thumbing through a box of old books at a local tag sale, and spied a title that piqued my interest : Fuel Economy of the Gasoline Engine: Fuel, lubricant, and other effects.
I could never look at a Holley carburetor again after reading it.
I was blown away to see that same book mentioned in this film:
[YOUTUBE]http://www.youtube.com/watch?v=1vJerAkLhuY[/YOUTUBE]
Wow, even if we could get 4 or 5 miles to the gallon with the stock Mercruisers, it would make a 200 plus fillup last twice as long. I'm amazed that more fart smellers haven't patented their devices and kept them, or even found "tree Huggers" with Deep pockets to make mass production possible. I'd buy an Aftermarket Carb or kit for $500.00 if it provided more torque, cooler Operating Temps, and even 10 more miles to the gallon on my Daily Drivers. Chevy 1/2 ton 4x4 and my Chevy Cruze. I drive about 40,000 miles per year between the two respectively and I spend a small fortune on Petrol. 90% of it is tax deductible, but still.. My Carbon Footprint is bigger than my Size 13's! There's a lot to be said for Ingenuity though. Well I'm off to start tweaking on odds and ends before the new shot of Awlcraft.
Hudson had water injection as a option back in the late 40's early 50's.My neighbor had it on his new Hudson,he used it for a while then just stopped putting water in the reservoir and disconnected the lines.In the mid 70's they sold a kit to put it on any car just never caught on (To Much Trouble to Keep Water in it) JOHN SR
cooling the fuel would create denser fuel, adding more to produce rich mixture. that could use more fuel unless the hp from rich mixture allowed for lean jets that were taking away hp. having said that, could make aluminum or copper coil around large spin-on fuel filter and recirc antifreeze thru tubing and cool can with dry ice(must be vented outside) or just run cool water thru tubing, might fix vapor lock?
Monte Carlo with a 455....skylark with a 327....they just mix and match everything out there huh??? HA!
I did build a cool fuel can myself for my grand national years ago. It worked, picked up a tenth in the 1/4 with it but we used to use dry ice. And pack ice on the intake between runs.
since the pump was electric I could circulate the blower oil with engine off, entire supercharger was ice cold at the beginning of every run. Was able to squeeze an extra couple tenths out of it with some injector tuning and that ice.
Later I went to a Novi2000 and a standard intercooler. Was faster but not as cool
Fuel coolers, designed to prevent vapour locking adding 15 to 25 percent more grunt?
What have I been doing wrong for all these decades?
Instead of more displacement, better heads, cams, valve trains, blowers, fuel systems, etc, I should have just stuck a Ford and a cool can in my Chevy.
PS, a Merc power steering cooler with modified fittings or an old oil cooler makes a great fuel cooler for the boat. I seriously doubt it makes even one more horse power but it does relieve some accumulated heat in my fuel after a trip past the injectors and through the regulator.
