Trs u-joints
Old 08-26-2012 | 07:42 AM
Unhappy Trs u-joints
Thanks to bob at marine kinetics and the guys at dart and afr I have a problem with holding my final drives together. It
Seems that the universal joint yoke - trans side - is far too delicate for the hp and torque my mouse motors are putting out.
Did anyone ever make a beefed up joint for trs/merctrans?
I don't mind breaking the yoke so much but each time it let's go I lose the gimbal housing
Konrads are the solution but not in budget right now
And yea I know the problem is my right hand!!
M
MagMark is offline
Old 09-01-2012 | 01:50 PM
Default U-Joints Failing
Mark, you need to find a better quality u-joint, as they should definately be holding up. I suspect something else also might be the cause, such as your dampner, or shaft(s) themselves.
CanDo is offline
