-   Classic Offshore (https://www.offshoreonly.com/forums/classic-offshore-199/)
-   -   GLOPRA Pictures (https://www.offshoreonly.com/forums/classic-offshore/289202-glopra-pictures.html)
CIG3 02-29-2016 07:18 AM
I raced in the boat with the bravo's it was a handful. My opinion was they mounted the drives way to high. On boxes they were around an inch above the bottom. This caused the boat the want to chine walk and run nose high. They ended up adding ballast to the nose which helped some. I liked the way it ran with the Arneson's much better. it just needed propped better which was a lot of cash back then.
Originally Posted by HTRDLNCN (Post 4401238)
Yup,I have that pic ,, looks like it was riding pretty neutral there which is what you want.
On the 36 race boat what Sal Picon did was run air lines from the top to vent the steps.
Worked well but the 36 was twin step .
Im also re-installing the ballast tank back in the front in case the big blocks make it a little nose happy..
Like I said it will just be a fun poker run boat so its probably not gonna see the seas or speed it used to, if I can get mid 80s out of it Ill be tickled pink. Its still a very solid boat and being the only one ever made makes it all that much more interesting..
term1032000 03-02-2016 10:01 AM
great pics
bck 03-08-2016 06:47 PM
Originally Posted by glassdave (Post 4409493)
ohhh i was schooled by someone from the area that berated me for pronouncing the "T" in Mentor . . . ever since then it has been Menner . . . . :D
I stick to the lower class neighborhoods. I know there is no "g" in Collinwood
J-Bonz 03-08-2016 08:02 PM
Yeah, but there are alot there that think they are "G's".... :)
legend 04-12-2016 05:07 PM
1 Attachment(s)
[ATTACH=CONFIG]553986[/ATTACH].
Mad Mother, Cheap Thrills, L.A. Express is almost complete and 1400 LBS Lighter
scippy 04-13-2016 12:03 PM
Great job she looks reborn!.......where did you shed the weight?............I know you lowered the cockpit sole, what other improvements did you make?
TENSION 04-13-2016 01:18 PM
Lose an engine?
Cary 29 04-14-2016 06:06 PM
Cig 3 was the arneson drive setup you mentioned spinning in or out. Thanks for the info. I'm rerigging my boat with Arneson s. Similar bottom. Cary 29'9"
CIG3 04-15-2016 10:55 AM
Spinning Out
Cary 29 04-15-2016 04:35 PM
Thanks probably 3 blades? I was told to spin in. I'm running 4 blades though with big diameter.
scippy 04-15-2016 09:26 PM
Cary you gotta post some pictures Bro!
Cary 29 04-16-2016 07:26 AM
Originally Posted by CIG3 (Post 4428784)
Spinning Out
I will email you some Skippy
legend 04-20-2016 08:57 PM
Originally Posted by TENSION (Post 4428052)
Lose an engine?
Went to single engine, lost transmissions with Bravo instead of TRS, took out all three tanks up front and installed light weight fuel tank behind cockpit, Built a 25 pound full length honeycomb engine hatch which goes from transom to the back of the two light weight racing seats with two inch aluminom monocot tubed cockpit, Full length 3/16 aluminum dash panel with six inch aluminum deck panel between seating and engine hatch, only a 4x6 ft honeycomb cockpit floor, deleted everything else that makes a stock cockpit, no back seat or heavy bolsters, light weight single engine layup, purchasing mostly aluminum engine components and exhaust. Lowered cockpit floor, light core built in fairing, very light but from the cockpit to the engine mounts, everything ties together. And still going.
Ryansean16 08-01-2017 09:25 AM
Originally Posted by legend (Post 3848623)
So then lets open another B-Wiser and keep looking at pictures. Cheers
that's our boat!! Nice pic!!
Samspencer66 09-08-2017 03:04 AM
Awesome old pictures. Thanks :-)
Thunderbuzzard 05-25-2019 04:28 PM
Original WMMS Radio Thnuder Buzzard P100
I was the original owner of the WMMS Thunder Buzzard P100 and miss GLOPBRA like crazy. It was the 1st Innovation 24 that was built with Kevlar and unfortunately, being the 1st is not always the best since we were plagued by broken stringers and delamination. It time to reconnect with Bobby Nielson from Eastlake, Ohio who was my navigator and never he let me down..
golfmaxgolf 04-22-2020 10:34 AM
Fantastic Thread, This never gets old!
benboat 02-19-2021 11:46 PM
Piranha
Originally Posted by h2oboater (Post 3880024)
Does any one know who owned Piranha, & if it was a single or twin engine 29' Mag??
I know this is an old post but my Dad, Ben Gommel owned and raced Piranha in the late 70s and early 80s. We owned Cuyahoga Boat & Engine in Cleveland and hosted several Glopra races. The boat had 4 Mercury outboard motors. This was the original Boar Hog. My Dad and I were just discussing how the boat would run with 3 of the new Mercury 600s.
Scorpion 17 07-12-2023 04:06 PM
Hey Benny! My name is Brian Matthei, My dad Red and your dad were crazies together back at Cuyahoga boat. I remember racing Pirannah with it's black maxes from the boat yard almost to shooters with Bill Steiskal in the Little Scorpion. The twin Volvos get pirannah out of the hole, but once the big Black Max power got that thing moving he got around us. I thought neither would let off and race to the lake, what a ride!
benboat 07-12-2023 11:18 PM
I remember your dad well and those were some crazy times. The Little Scorpion is in Vermilion now running a single big block. I saw it on July 4th.
