KAAMA Scarab scale model >
Old 01-19-2015 | 04:02 PM
  #41
Is this the same boat? http://www.nationalpowerboat.com/38_...t_scarab-2.htm
Can anyone tell me what this gauge cluster is under the center part of the windshield?
Ken_NJ is offline
Old 01-19-2015 | 04:38 PM
  #42
Very cool do you have any scratch build plans or copies of your kit plans =pm me
JETTDOGG is offline
Old 01-19-2015 | 04:42 PM
  #43
Team Archer's Avatar
tach's and indicators they add a little pod so that you didn't have to look down so much it was in front of you. That's a picture of Bettys boat notice the steering is on the right side so she could see out
Team Archer is offline
Old 01-19-2015 | 05:38 PM
  #44
Dan, looks like Betty controlled the forward/reverse operations as well as the steering maneuvers around the docks. I don't see any rocker switches for the tab and drive trim angles. How where the controlled? Are those push buttons on her right involved, looks like it says flaps above one set. J sry not wishing to hi-jack the OP.
I'CE is offline
Old 01-19-2015 | 05:46 PM
  #45
Yes fwd and rev were controlled by the driver around the dock but remember they were crash boxes. the trims were controlled by the two rocker switches under the grab handle and the buttons were overrides .
Old 01-19-2015 | 05:47 PM
  #46
There are two sets of buttons if you look closely one set by the wheel and the other at the far side of the small gauges.
Old 01-19-2015 | 07:47 PM
  #47
Jettdog, no plans on the model. As I see and find more pictures and see details, I make up the parts as I go along, basically winging it and come as close as I can. Your not hijacking for sure as I'd like to learn as much as I can so ask away.
My model as I found out happens to be an S type Scarab which is 30 feet and resembles this one: http://www.gm-powerboats.com/shop/da...061216_009.JPG
Is this Betty's boat before it was KAAMA?
So the set of 8 buttons are for the trim tabs with a duplicate set on the port side? And the switches under the grab are the override? Are the levers to the right for reverse?
Ken_NJ is offline
Old 01-19-2015 | 08:13 PM
  #48
No that was Joey Ipolito's boat different than Betty's and yes you are correct about the switches and the shift levers the switches do both drives and tabs
Old 01-19-2015 | 09:57 PM
  #49
Ok I see the rockers... so she had the start buttons and kill switches to her port....ya thanks Crash Boxes PIMA .. wish there was a nice close up of the dash and its labeled redundancies. J
I'CE is offline
Old 02-14-2015 | 03:29 PM
  #50
Charlie mentioned the orange on KAAMA was international orange so I found a Model Masters International Orange and used that.
Here's the entire painting sequence of the hatch and engine covers. Not that I should point out my mistakes, I got the sizing on the numbers a bit too small.
Ken_NJ is offline
