New guy looking at a Wellcraft Nova 250 XL
New guy here. A little bit of experience with boating, not much, I have owned a couple of under 20' pleasure boats. I am considering purchasing a project boat and looking for a little guidance. Any help would be appreciated.
I am looking at 79' Wellcraft 250 XL with twin SBC's. Both engines run, one rough, one okay. No idea of the condition of the drives, hydraulics or electrical. No soft parts in the interior with the exception of the captain's seat. Some gauges work, some do not. The hull looks to be in good condition, but I do not have a clue what I am looking at or for. I did notice the hull seems to have a very rough surface below the water line, not sure if this is normal? There is also a crack in the fiberglass around the door frame for the cuddy entry, about 3', on the top of the frame. Any insight on how to inspect this thing prior to purchase would be appreciated. I am comfortable performing any needed mechanical or electrical repairs, I have a pretty solid automotive background, I just want to make sure the "boat" stuff is in good or at least repairable condition before I make an offer. Not a clue what to offer either, any help? I will try to take a few pics and post them. It is on a trailer, that IMO, seems a little light duty for a boat of this size, no title for the trailer, but that should not be too big of an issue in my state.
Sounds like a project, not sure if that’s what your looking for or not. Some guys are working on there project boats for years. Was it stored outside? Was it covered? How long has it sat? Would you be willing/able to pull motors and drives and rebuild or have them rebuilt?
Might be best to have a professional boat surveyor inspect the boat. Not trying to scare or deter you, but boating as a whole, from pontoons to go-fasts, get a bad wrap when people bite off more than they can chew.
The Nova 250 is a great boat, the hull rides really nice, handles ugly water well, doesnt do anything unpredictable. With nice running 350s it should be about a 60 mph boat. Those stock 350 merc motors are cheap. and plentifull dont worry about that, the abiggest thing to check, taje a hard screwdriver handle or a little mallet and start gently tapping all over the transom, inside and out, tap on the bilge liner/tub if you can pull one of the lag bolts on the front engine mounts, and check the wood. When tapping it should sound solid and bright, it the wood core is wet/rotted it will sound duller. Gauges you mention may be bad connections or just bad, again easy and not to expensive to replace.. Drives will be alpha's should be relatively bullet proof behind a stock 350, a new aftermarket drive is only 1200. Without seeing it, somewhere between 3 and 6000 if decent condition,,,,, the rough surface bottom paint?? from what you describing, if one motor is rough, some gauges not working etcyou could be somewhere between 1500-3000.
When I bought my 77 in 2004, the transom was bad, I paid 1000 for it.
I am okay (and capable) of doing some heavy work, pulling an engine or drive. I just want to make sure I do not get into too much of a money pit, I know any project will always turn out more expensive then you initially allow for. I feel I would enjoy the process and have fun with it, with my family, when done. My biggest apprehension is paying too much initially and not understanding what I am looking at as far as the main structure of the boat.
