Scarab Panther Advice, Help! >
Old 05-29-2018 | 09:00 PM
Default Scarab Panther Advice, Help!
Hello, Just bought an 86 Scarab Panther, has 7.4 Merc's and BW Trans w/TRS. I thought I may have gotten a good deal, but need some advice. Took it out over the weekend, all was well, engines sound and run very smooth. Boat overall is in good shape for the age inside/out. After a few trips, and maybe an 1.5 hours total use went to back out of my slip, and no reverse. It was working just fine when I backed out of the slip before, no hard shifts, hardly used reverse much, and returned to neutral between gears. Really only got the boat up to full speed once mainly just cruised 25-30.
A few questions... Is there any type of neutral/safety switch which would cause this? Forward still works fine on both engines, and can see shifters are moving the cables properly to engage reverse. Just find it odd both would go out at the same time with no real cause.
If it needs tranny work, I live in Virginia... Any recommendations? Anything else I should be aware of checking? It's been raining here a bit, anyone know the exact model BW trans these have? Any estimate what it would cost to pull engines/BW's and rebuild?
Dboss33 is offline
Old 05-29-2018 | 09:06 PM
jeff32's Avatar
Oil level?
jeff32 is offline
Old 05-29-2018 | 10:13 PM
hblair's Avatar
Both sides have no reverse?
hblair is offline
Old 05-30-2018 | 06:07 AM
Oil seems fine, not milky etc. checked levels after use... No reverse either side.
Dboss33 is offline
Old 05-30-2018 | 08:25 AM
phughes69's Avatar
checking fluid level on a BW trans is tricky. you need to check it right after it is shut down. I would disconnect the shift cable from the shift lever on the trans and manually check it. The BW trans has detents that click when it is properly in gear. Your forward adjustment could be fine but reverse is not traveling back far enough.
phughes69 is offline
