Efi conversion bpm vulcano 450 >
Old 12-08-2019 | 04:12 AM
Default Efi conversion bpm vulcano 450
Newbie here to this forum...has anyone of you ever came across a converted from carbs to efi and if so could i please have some info????
tnx in advance
Motronic is offline
Old 12-08-2019 | 08:57 AM
to start w/,your gonna have to machine your intake manifold for fuel injectors.then its just a matter of picking 1 of the dozen aftermarket fuel injection systems and wiring and plumbing it up.
sutphen 30 is offline
Old 12-09-2019 | 02:24 AM
Thx for swift reply, going the hard way was my initial thought, but I was hoping that somebody here will know if there is a hint for reference with other similar v8 induction manifolds....
Motronic is offline
Old 12-09-2019 | 06:21 AM
what about a tbi carb replacement setup??
phragle is offline
Old 01-13-2020 | 05:24 PM
TopSpin80's Avatar
after doing a bit of research on this topic for my boats. I think this is the most simple option:
https://www.holley.com/products/mari...er_efi_marine/
But you are also going to need to figure out how to get an o2 sensor in the exhaust. There are blocks already setup for this that can be bought for the merc stuff.
Ernie
TopSpin80 is offline
Old 01-15-2020 | 08:55 AM
I do acknowledge of Holley systems but unfortunately because of induction manifold design at 2 or even full body set up is not applicable scince vulcano has 4 pairs of downdraft carbs....
Motronic is offline
Old 01-15-2020 | 10:25 AM
Default EFI converstion
I have just had Two 540 ci Chevy motors fitted with the old school 8 induction stacks converted to EFI. and it is not for the faint hearted.
You have suitable induction system so a Holley common rail setup would work but unless it has been done before it will all be "custom" which if you have the facilities and a dyno is not a problem and I know can be made to work.
Do you want to do this yourself or are you looking for an engine shop to do it for you ?
Kalaazar is offline
