-   Cobalt (https://www.offshoreonly.com/forums/cobalt-251/)
-   -   I think ECM- help (https://www.offshoreonly.com/forums/cobalt/216983-i-think-ecm-help.html)
trukwurks 09-16-2009 07:58 PM
I think ECM- help
I have a 98 cobalt 252 7.4 mpi Volvo . Ran great until the other day. Shut the boat of and now it wont run. It has spark, seems the computer is not allowing fuel. I was told I need an ECM. But I cant find one. Does anyone have a source.
Is this a common problem...
Brad Johnson 09-16-2009 09:24 PM
ECUs hardly ever go bad, check fuel pressure, and your deadman switch (tether on your control), check the breakers & or fuses on the motor. I can get an ECU if you need one, but I bet that is not your problem. I have to head out for a race in San Diego this weekend later tonight. I will be back Monday night, call me on Tuesday if you have not figured it out.
Brad
530-525-1638
trukwurks 07-02-2010 10:41 PM
Its been a while but I am still having this issue. I was not getting the 12volt to the fuel pump relay. So I jumped the 12 volt to the relay and it ran great for about an hour, then stalled. When I restarted the she jumped to three thousand RPM and stayed. I have replaced the oil pressure sender and re-fastened all the grounds.
I have a hard time believing its the ecu. It has to be something silly.
Any help on this would be great.:party-smiley-004:
alindquist 07-12-2010 10:29 AM
Check your breakers, there should be one hidden down by the low pressure fuel pump, and I think 3 right on the front of the engine... I had a very similar problem (I have the 7.4gi in a 99 232 Cobalt), and what happened was the lower pressure pump went bad and tripped the breaker which also controls the ignition. I did end up replacing the fuel pump and it runs fine now. If you don't get anymore help here check the Volvo forum on www.iboats.com and post there, there are a lot of Volvo guys on there that have helped me out in the past.
trukwurks 09-25-2010 03:27 PM
Thanks I am back into this project. My work does not allow me any free time during the summer. So now I can jump back into this.
I will check the relays and replace the low pressure pump.
trukwurks 06-30-2011 06:48 PM
As crazy as this sounds, I am still trying to fix this. I have replaced the relays and both fuel pumps. Today I borrowed a scanner from a friend and I get code 43. Electronic spark control malfunction.
Any info would be great.....Thanks
