-   Concept (https://www.offshoreonly.com/forums/concept-252/)
-   -   36' Concept, Prop Question ? (https://www.offshoreonly.com/forums/concept/275073-36-concept-prop-question.html)
Groper 04-23-2012 03:52 PM
I have a 36' with twin 300 Verado's
The Boat arrived with Three Blades from the factory, 21" Vented with 1/2"holes.
It comes out of the hole and on plane very quickly, hits 6400 rpms @60mph. with no tab adjustment and very little trim.
What other props have worked well with this application ?
Thanks in advance
allstarmarine 04-24-2012 10:17 AM
1 Attachment(s)
Allstar Marine just completed testing on a 2008 36' Concept with a pair of 300HP Mercury Verados. The guys from Concept were very helpful with information and assistance. Below is our results.
Prop Testing:
Customer Props
Props: Mercury Enertia 21 Pitch 3 Blade Props
Part #: Mercury 48-89902/03
Fuel: 163 Gallons of fuel
Trim: 3.4
Rotation: Props Rotating Out
Slip Rate: 14%
RPM: 6400 (5800-6400)
Speed: 61.3 MPH
Customer Props
Props: Mercury Inertia 21 Pitch 3 Blade Props
Trim: 3.4
Slip Rate: 14%
Speed: 62.4 MPH
Allstar Propellers
Props: Mercury Bravo 1 22 Pitch 4 Blade Props
Part #: Mercury 48-831909/10
Trim: 5.0
Slip Rate: 11%
RPM: 6100 (5800-6400)
Speed: 64 MPH
Allstar Propellers
Trim: 7.0
Rotation: Props Rotating In
Slip Rate: 12%
Speed: 67.1 MPH
Groper 04-26-2012 12:18 PM
Great information, have you tested any Herrings on thes Boats ?
allstarmarine 04-26-2012 12:29 PM
Groper,
I sent you a PM
Fred
Allstar Marine
baja36ft 05-15-2022 06:03 PM
36 concept props turning in?
Prop Testing:
Customer Props
Trim: 3.4
Slip Rate: 14%
Speed: 61.3 MPH
Customer Props
Trim: 3.4
Slip Rate: 14%
Speed: 62.4 MPH
Allstar Propellers
Trim: 5.0
Slip Rate: 11%
Speed: 64 MPH
Allstar Propellers
Trim: 7.0
Slip Rate: 12%
Speed: 67.1 MPH
How did the boat handle with the props spinning in?
I have an 2005 36ft with 275’s spinning labbed 22’s 4 blade
