-   Deep Impact (https://www.offshoreonly.com/forums/deep-impact-256/)
-   -   Quick shot of the new 39... (https://www.offshoreonly.com/forums/deep-impact/250456-quick-shot-new-39-a.html)
Tim G. 03-30-2011 07:59 PM
1 Attachment(s)
Well on it's way!
The hull and deck are final for the Open. The console, top and helm seat are in process...
More to come...
Cash Bar 03-30-2011 09:43 PM
I like it.
Projections for weight etc?
Tim G. 03-31-2011 07:21 AM
It should be 13,000lb with trip Verados...
bgck13 04-12-2011 10:01 AM
I'd like to see 4 of the Seven Marine CTS-V outboards on that bad boy. :D
Tim G. 05-05-2011 04:47 PM
First hull is out of the mold
3 Attachment(s)
Moving along...:drink:
Catmando 06-01-2011 05:03 PM
I remember the first DI test I saw they said it weighed 16,500lbs. :eek: I thought that was a bit much for a 36' boat even with quads...
Has anyone put suspension seats in a DI? If so how much did they cost?
Tim G. 06-01-2011 09:48 PM
That weight was off considerably... The boats don't weigh 16,500lbs....
Catmando 06-03-2011 12:05 AM
Yeah that's what I was thinking too, didn't sound right...
How much weight does the quad transom add? I think that article said but I don't remember.
Tim G. 06-03-2011 07:43 AM
We build all the boats with the same materials in the transom now.... The only difference between the triple and quad is just the width of the well area.
The transoms are cored with 24lb density foam in 1" layers with two glass layers between each layer of foam, then capped. All get knuckles on the outer joint.
Stringer arrangement changes triples to quad.
I get the stringer and transom foam pre cut via CNC, as well as each layer of fiberglass and core. It is a hand laid vinylester layup, but I took the trimming and overlap factor out of most of it....:drink:
Enough 4 Play 08-01-2011 08:55 AM
Deep Impact in Chicago
There was a Deep Impact CC in Chicago with maroon sides , white deck and brown leather interior. The boat was absolutely stunning!!!
