Go Back  Offshoreonly.com > Owners Forum > Deep Impact
Water Pressure breaker >
Old 03-11-2020 | 08:41 AM
Default Water Pressure breaker
Anyone know what the water pressure breaker on the breaker panel in the cabin of a 2005 36CC does? I have separate fresh and salt water pump switches on the dash that work those pumps. I’m trying to figure out what the breaker below does. When I flip it on, I hear a pump come on that sounds like it’s near the bathroom.
tony97gt is offline
Old 03-11-2020 | 08:42 AM
pressure pump for the sink and head?
Easy to check.. with the breaker off, turn the water in the sink on and run down the water/pressure. With the water pressure running low, turn on the breaker - if the pressure bumps up - that's definitely what it is for.
speicher lane is offline
Old 03-11-2020 | 08:48 AM
doesn’t seem to make any difference with the breaker on or off, tried that.
tony97gt is offline
Old 03-11-2020 | 08:49 AM
the sink and head run off the fresh water pump switch on the console.
tony97gt is offline
Old 03-11-2020 | 01:57 PM
it might be the pump to the shower gray water instead of dumping in the bilge it goes in a container and gets pumped overboard or to a gray water tank....or it could be a wash down pump
boostbros is offline
Old 03-11-2020 | 05:16 PM
Overload protection for the water pumps? The switches at the helm most likely just that, a switch, not a circuit breaker. Just from your description to me it sounds like if water pressure got too high from a pump running too long etc, the pump overloads, draws too much current and the breaker trips. I could be looking at it totally wrong but that’s what I get out of it from the description.
IGetWet is offline
