Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
how to clean rub rail???? >
Old 07-31-2005 | 04:36 PM
gsmith9898's Avatar
Default how to clean rub rail????
How do you get the black marks off your white rub rail?
gsmith9898 is offline
Old 07-31-2005 | 05:20 PM
offthefront's Avatar
Default Re: how to clean rub rail????
I think Acetone ....someone will chime in ....but ONLY on the rubrail ....
offthefront is offline
Old 07-31-2005 | 06:08 PM
Steve_H
thats what i use also.
Old 07-31-2005 | 06:35 PM
gsmith9898's Avatar
wipe on and off? I tried thinner and it didn't work.
Old 07-31-2005 | 06:42 PM
Steve_H
just put some acetone on a clean rag and drag it across with some elbow grease. may have to go over it serveral times if its really marked up. it evaporates pretty fast.
Old 08-01-2005 | 12:34 PM
berco's Avatar
S.O.S. pad only on the rail though be careful works great
berco is offline
Old 08-01-2005 | 09:13 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Used the acetone on my old rubrail insert with fair results. Don't soak the rag, just damp, then work fast. Soaking it will make the insert soft. Try to keep off the molding. But I did use a rag at times heavy with acetone to rub out scratches in the molding. It softens the plastic enough that you can rub across the scratches until it 'melts' smooth. I did notice that the insert got dirtier faster and easier and lost the shine after using acetone. Ended up replacing the insert with a new one and no longer use acetone. Black streak remover or bleach white only now.
US1 Fountain is offline
Old 08-01-2005 | 09:42 PM
gsmith9898's Avatar
my rub rail is one piece hard rubber.
Old 08-01-2005 | 10:58 PM
dykstra's Avatar
acetone
dykstra is offline
Old 08-02-2005 | 09:52 PM
G Man's Avatar
What happens if you get acetone on gel coat???
G Man is offline
