Awgrip
Old 04-20-2008 | 09:35 PM
Audiofn's Avatar
Charter Member #232
I miss Durathane!!!
Put your best foot forward!
Audiofn is offline
Old 04-21-2008 | 04:02 PM
Enforcer2's Avatar
From: Ocean Pines, Maryland. Wish I was at MANGOS in MIAMI!
black Awl Craft...just finished yesterday.....now for the top deck
Attached Thumbnails Awgrip-black-paint.jpg   Awgrip-black-paint-2.jpg   Awgrip-black-paint-3.jpg
Enforcer2 is offline
Old 04-21-2008 | 04:05 PM
Enforcer2's Avatar
few more
Old 04-21-2008 | 05:18 PM
glassdave's Avatar
Neno the mind boggler
looks great! See ya in a month or so.
08 OPA High Points Champion
glassdave is offline
Old 04-21-2008 | 08:28 PM
Enforcer2's Avatar
Absolutely!!SEACRETS is awaiting or arrival!!.
Old 04-22-2008 | 11:58 AM
madbouyz's Avatar
It wasn't that you cant buff it its that you shouldn't buff it. I believe all the UV protection is at the surface and if you take that off it can effect the life of the product. Somebody correct me if i'm wrong. Has anyone buffed it and been able to monitor the surface over time to see what it does? Curious about the stuff because its not something i use regularly
I have seen Spot repairs (or 'blow ins') done (on regular Awlgrip) and they entailed plenty of compounding/waxing (Not sanding though) to make them appear to blend in.
Looked fine in the limited light of the workshop. Two months later out in the elements there was a huge tan coloured halo around each one and premature chalking.
That's why I've always said .... With Awlgrip , the finish that comes out of the gun is what you get !
madbouyz is offline
Old 04-22-2008 | 12:24 PM
glassdave's Avatar
Thanks man, thats kinda what i thought. I know they are adamant about NOT buffing Awlgrip. I figured it had to with UV surface protection and that would about verify it.
I developed a technique for gunning in that requires no buffing if need be. I wont say its a 100% perfect but it is a very nice blend and can be left as sprayed if necessary. I had to come up with something for repairs in the middle of a boat as it isnt feasible to shoot the whole side, unless of course it is a repair to a custom fade. In those cases you have to re do everything.
Is it still possible to spot in Awlgrip if you dont buff the blend?
Old 04-22-2008 | 01:10 PM
madbouyz's Avatar
Is that for regular Awlgrip that you're talking about ? ?
As for the spotting in of Awlgrip , I'm not a pro painter, I can only tell you what I've seen done in the recent past. I can't imagine doing a spot and then NOT having to blend it in with a lot of compounding and waxing etc. The stuff never flows into the existing finish smoothly. I don't know if Awlcraft 2000 is any better at that but at least it's buffable.
madbouyz is offline
Old 04-22-2008 | 01:39 PM
glassdave's Avatar
oops, sorry i didn't clarify, actually its a technique i use for spot clear over a basecoat repair. I just wonder if Awlgrip sprays similar enough for it to work. Works pretty good and as i said not 100% perfect but most people off the street probably would not notice the blend. I suppose it may not work with Awlgrip now that you mention flow out because it requires a bit of over thinning.
I dont use Awlgrip much, in fact its been years but i like to keep up on things. Thanks.
