Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Removing old registration numbers >
Old 04-24-2009 | 11:04 AM
Default Removing old registration numbers
I have to remove old reg. #'s that have been on the boat for 24 years. What can i use that wont hurt paint/gel coat?
Wannabe
wannabe is offline
Old 04-24-2009 | 12:19 PM
Is it gel or is it paint. Big difference on what chemicals you can use. 3M makes a wheel that is designed just for this and would be your best bet.
Griff is online now
Old 04-25-2009 | 03:30 AM
cig1988's Avatar
If its vinyl use this:
http://www.autobarn.net/3m-07498.html
cig1988 is offline
Old 04-26-2009 | 05:55 AM
masi242's Avatar
I have used a heat gun and a blow dryer, you just need it warm up the numbers to make it pliable again.
masi242 is offline
Old 04-26-2009 | 03:05 PM
marine shop said heat gun, plastic edge scraper. TRhere is a 3m product to remove old adhesive.
Wannabe
wannabe is offline
Old 04-27-2009 | 10:16 AM
heat gun, and any glue that is left just use a dilueted acetone or goo gone on a rag to remove any that is left.
Splitdecision271 is offline
Old 04-29-2009 | 08:33 AM
Split. Thanks for the sugestion of Goo Gone. I have some and will try that.
Wannabe
wannabe is offline
Old 05-07-2009 | 11:41 AM
After you remove old vinyl graphics or registration numbers there is typically a difference in the gel coat (you can see the ghost of what was there before).
What grit sandpaper or rubbing compound should be used to get rid of the "ghost"?
Powerquest_Baby!! is offline
