-   Detailing, Painting, & Fiberglass (https://www.offshoreonly.com/forums/detailing-painting-fiberglass-167/)
-   -   How to add Stainless mirror to hatch? (https://www.offshoreonly.com/forums/detailing-painting-fiberglass/208422-how-add-stainless-mirror-hatch.html)
verbi69 05-08-2009 06:32 AM
Not sure if this is the right spot to ask but...
I want to put mirrored stainless to the underside of my hatch.
The underside is smooth....do you glue it on???
David Stotz 05-09-2009 09:07 AM
Not sure why you want to use stainless. I think most people including myself use plexiglass. In any case I would us some fasteners.
Dave
verbi69 05-09-2009 02:05 PM
The mirror on the underside of the hatch would it not be mirrored stainless......like the hatch undersides of Donzi and Sunsation??
I am curious to the thichness of the fiberglass hatch...is it as simply as using a short screw and not going through into the foam??
CignificantOther 05-09-2009 03:25 PM
I initiallly tried special "mirror adhesives" on the plexi/Lexan ..............save the money and headache of two applications. Use 3M 5200 and a few small screws around the edges. Install upside down, with weights, and let it dry 36 hours or more.
Strip Poker 388 05-09-2009 04:39 PM
Im trying to do the plexyglass,still unsure.
http://www.offshoreonly.com/forums/g...do-i-need.html
verbi69 05-10-2009 09:28 AM
Thanks....I assumed that all mirrors under the hatch were stainless.I didnt realize that there is a mirrored plexiglass!!
David Stotz 05-10-2009 09:41 AM
69,
How thick is the hatch? I never thought about it because mine is 3/4" marine grade plywood. If you use the plexiglass you need to put some type of thick rubber washer between it and the mounting surface where the screws are or the mirror finish will scratch because it's on the underside.
Dave
verbi69 05-11-2009 11:43 AM
Thanks guys...I will poke around under there and see what i have.......
Strip Poker 388 05-11-2009 01:27 PM
I just got a price on 2 sheets plexi 140. each
shipping around 100.
verbi69 05-11-2009 04:49 PM
2 sheets - how big??
You shipping that to me??
