Moisture reading?
Old 11-21-2009 | 09:54 AM
Good post Steve.
PJDiesel is offline
Old 11-22-2009 | 12:10 AM
J-Bonz's Avatar
Originally Posted by Steve Snider
I am a marine surveyor and the moisture meter is one of my tools that I use on every boat. The moisture meter does indicate moisture although it can also indicate a high reading due to a void in the laminate or wood in the transom. Sounding the area with a phenolic hammer will help determine if moisture is present. The ONLY real proof of high moisture is to use destructive testing to get a core sample or drill a small hole to see if water runs out. It should also be noted that bottom paint and some resins also will set off a moisture meter to read high moisture when there really is no moisture in the laminate. The moisture meter is a tool that is valuable to use around thru-hulls to determine if the thru-hull is bedded properly. The moisture meter is a tool that indicates possible moisture. Follow up testing should be used to prove the mosture meter reading.
Well said Steve!!
Jr.
J-Bonz is offline
Old 04-22-2010 | 12:12 AM
Thanks for the valuable info. How often does a '98 trailered powerboat show excessive moisture? I am wondering if a 10-12 yr. old well built boat would likely be in acceptable limits.
txwatergypsy is offline
